http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#2 |
Did it Himself
Is the speaker signal going in to Negates? Not sure what's going on with that second op-amp, it looks like it will be keeping the LED on all the time?
Those have got to be the most hideous and confusing resistor symbols I have ever seen!
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
The second comparator drives an LED. The resistor symbols are quite big to hold value and wattage as well as the reference number.
#4 |
Did it Himself
So are both op-amp things actually comparators? I think you need to use op-amps otherwise the input to the second "comparator" is just going to be high all the time due to the pull-up resistor.
#5 | |
The pot is always set to around 5 volts and is adjusted for the LED to come on at the onset of clipping. The first comparator switches low and discharges the capacitor quickly when clipping occurs. The capacitor then charges up slowly once clipping has gone and os keep the LED on for a while.
#6 |
Did it Himself
OK I was thinking the other way round. It is late
![]() Seems it should be ok then. Get the breadboard out if unsure
#7 | |
Best to try before going to a proper PCB.
#8 |
| Will this circuit work? | Kolloi | Solid State | 3 | 26th February 2008 05:20 PM |
| 813 SE circuit,will it work? | Richard Ellis | Tubes / Valves | 6 | 19th November 2006 03:05 PM |
| Would this circuit work??? | cunningham | Solid State | 10 | 31st January 2005 05:16 PM |
| How does clip protection work? | Pbassred | Solid State | 13 | 24th May 2004 06:22 PM |
| Page generated in 0.10153 seconds (77.37% PHP - 22.63% MySQL) with 10 queries |
