I’m trying to work out the phase shift for 330Hz through an all pass filter which has a value of 68K for R1 & 10nf for C1.....
shack.us/i/diagram1.gif/] [/URL]Now formulas aren’t a strongpoint of mine, but apparently, this one will provide the phase shift for any given frequency through the above circuit …. ![]() (source = http://www.maxim-ic.com/appnotes.cfm/an_pk/559 Where where w is the frequencies in rad/s. I want to determine the phase shift for 330Hz, so I used this online calculator to get that converted to radians per sec http://www.sciencelab.com/data/conve...nversion.shtml therefore w (radians per second) for 330Hz is 2,073.451149 R1 = 68,000 C1 = 0.00000001 Ok, don't laugh, but I tried to use that formula above.... Top part of the equation (within the brackets)…. 2 x 2,073.451149 totalling 4146.902298 divided by 68,000 (ie R1 @68K) x 0.00000001 (C1 @10nF) totalling 0.00068 Therefore 4146.902298 divided by 0.00068 = 6098385.7323529411764705882352941 (this is the top number within the brackets) Bottom part of the equation (again within the brackets)…. 4299199.667289420201 (ie ‘w’ or 2,073.451149 squared) Minus…. 1 divided by 0.00068 = 1470.5882352941176470588235294118 Which then must be squared = 2162629.7577854671280276816608997 Therefore we end up with 4299199.667289420201 - 2162629.7577854671280276816608997, resulting in.... 2136569.909503953072972318339101 (this is the bottom number within the brackets) Therefore to get the number within brackets, we must divide the top number by the bottom number… 6098385.7323529411764705882352941 / 2136569.909503953072972318339101 Therefore the number in brackets is 2.8542879431306799315135558591161 Now a scientific calculator tells ne that the tan of the above number is 0.049857973507496406210421036060919 degrees. now tan -1 means I must shift the decimal point one place to the right? So, am I right in thinking that the phase shift @330Hz through the above all pass is just a mere 0.5 degrees? Last edited by HankMcSpank; 4th October 2009 at 11:08 PM. |
#2 |
Did it Himself
Excellent working there, just a small mistake at the very last hurdle. Tan -1 means inverse tan, you should have the function on your scientific calculator, usually shift or 2nd then press Tan.
So you need to find the inverse tan of 2.8543 which is approx 70.7 degrees.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
some of us are just lazy - let (Free!) software do the math
![]() the inset is SciLab console calc for those who need better than the LtSpice cursor resolution Last edited by jcx; 5th October 2009 at 12:18 AM. |
#4 |
Thanks richie00boy - I knew that if there was likely to be a mistake, it'd be in the last part ...as I've not used tan, cos, etc since leaving school about 30 years ago (& thanks for not laughing!). On the standard XP 'calculator ...in scientific mode, do you know how to do an inverse tan on it?
That said, in the light of jcx's post above - it looks like either the formula in that Maxim sheet is wrong...or my interpretation of it is! jcx ...I'm all for letting the software take the strain - & I note that it's got to a different outcome than my calculations - 331Hz through that circuit has a 109 degree lag ...I'd love to know why! (I'm assuming there's is right!). I'll try & work out how to get access to what you've got there - it looks funky (though the thought of having to knock up the whole circuit just to establish a phase shift isn't that appealing - I guess once it's done once though....) Last edited by HankMcSpank; 5th October 2009 at 09:29 AM. |
#5 |
Did it Himself
Simply tick the Inv checkbox on the second row of buttons below the display.
Sometimes simulated circuits show different results because op-amps have their own phase shifts as well, but it's usually just a very small difference. Something else is amiss.
#6 | ||
When I get a mo, I'll try again, but this time rather than covert to radians per sec, maybe I'll just give it a go with Frequency, extract from that datasheet.... ![]() "where w is the frequencies in rad/s, or 2×pi×f, when f is in Hertz. " Last edited by HankMcSpank; 5th October 2009 at 10:05 AM. |
#7 |
Ok, I used Excel (using Radians per sec again)...
Input Values…. Resitance =68,000 Capacitance =0.00000001 R1C1 =0.00068000 w (Radians per sec) =2,073.451149 w² =4,299,199.66728942 Top Line of formula 2w = 4,146.90229800 R1C1 = 0.00068 Result (2w / R1C1) = 6,098,385.73235294 Bottom Part of formula (sub brackets) 1 / R1C1 = 1,470.58823529 Bottom Part of formula w² minus 1 / R1C1 = 4,297,729.07905413 [w² minus 1 / R1C1]² = 18,470,475,236,947.4 Inverse Tangent of 18,470,475,236,947.4 =89.99900000 (let's call it 90 degrees!) So a different figure again! I am uncertain which order to do the maths on the lower part of the equation.... do I square 1/R1C1 then subtract that result from w² *or* do subtract 1/R1C1 from w² & then square that result? |
#8 |
Did it Himself
The first one. If it was all to be squared there would be brackets around the whole bottom part with the square to the right of it. Although very occasionally you do get poorly written formulas.
#9 |
Ok, richie00boy ....we were right with our first calculation!
The phase shift at 330Hz for an all pass filter circuit with the values of 68K & 10nf is +70.69213237 degrees How do I know? Well, I know the centre frequency for that circuit with those resistance & capacitance values - it's approx 235Hz (where this will yield a 90 deg phase shift). Here's the formula for the centre frequency... 1 / 2xPi x C1R1 So then I created a spreadsheet to work out what the same circuit's phase shift would be for 330Hz....it came out at +70.69213237 degrees. Then, in my Excel spreadsheet's cell - where I enter the frequency as an input - I changed it to 235Hz (the centre frequency of the circuit) ....& the spreadsheet result changed to 90 degrees (ie the centre freq phase shift) ....bingo! Alas, I'm unable to upload the spreadsheet, as this forum doesn't allow Excel Spreadhseet uploads. But if anyone wants a copy of the spreadsheet drop me a PM with your email address. Last edited by HankMcSpank; 5th October 2009 at 12:06 PM. |
#10 |
109.307... degrees is the "correct" answer
the sim's -109 comes from the software's phase unwrapping algorithm a simple calculator style atan function is going to return a value between +/- pi/4 rad == +/-90 degrees while the "true" value of the phase shift may have an additional +/-n*180 degree phase at "0" freq the cap is open and the circuit has a +1 gain == 0 phase shift at high freq the cap is a short and the circuit is an inverter with -1 gain == 180 (or -180) degree phase shift so the phase shift smoothly varies from 0 to either of +/-180 which means it goes beyond the +/-90 range of the elementary atan function I believe the sign ambiguity enters with +/-180 degrees being "equal" so the software chooses one - probably using the magnitude response slope - which would be correct for a minimum phase circuit - which this is not if you sim the circuit with a .tran you can see the phase shift is clearly greater than 90 degrees at 330 Hz, a frequency sweep should show the phase smoothly varying as I described above Last edited by jcx; 5th October 2009 at 02:17 PM. |
| Zero phase-shift | gareth | Solid State | 11 | 9th May 2008 04:45 PM |
| Signal phase shift through a tube amp | d1camero | Tubes / Valves | 8 | 13th November 2006 03:18 PM |
| Creating positive phase shift? | Pabo | Class D | 31 | 14th January 2005 06:44 AM |
| Hybrid amp phase shift oscillation? | Duo | Solid State | 5 | 21st October 2004 08:16 AM |
| Zen Phase Shift, Feedback in BOZ | Jay | Pass Labs | 3 | 17th February 2003 04:36 AM |
| Page generated in 0.13755 seconds (83.66% PHP - 16.34% MySQL) with 11 queries |
