Can someone explain to me how to test for dc offset? I'm just finishing a set of Thor speakers and want to be sure I'm not running dc through them. I'm using an old Rotel amp with an mp3 player connected. Thanks.
#2 |
Short the inputs of the amplifier and measure the DC component on the output with a multimeter.
#3 |
#4 |
Yes, to measure DC offset accurately. I my experience the DC offset will measure higher without shorting the inputs.
What if there is a earth lift resistor on one of the inputs? Should both inputs be connected to earth instead? EDIT: Usually we measure DC Offset to test for an amp failure. This is usually indicated by the DC offset being approxiately equal to the rail voltage, so the absolute DC Offset value is not that important as long as it is the millivolts range.
Greg Erskine Last edited by Greg Erskine; 4th October 2009 at 09:13 PM. |
#5 |
Lots of amplifiers have a input coupling capacitor so shorting the input won't have any effect. But, it only takes a second to short the pins on a cheap interconnect with a screwdriver.
Kevin |
#6 | |
Fotios |
#7 |
Same thing with balanced inputs? Both hot and return tied to signal gnd, preferably right after the coupling caps - if any.
#8 | |
The issue it is that, the coupling caps (yet of high quality like polypropylene foil) they present by alone a significant DC offset (up to 200 - 300mV) due to their coupling with the rest input filter parts of amplifier. Usually after the out leg of input cap it is soldered a series resistor (from 1 to 2,2KΩ) and in the out leg of this resistor it is soldered another one parallel (to Gnd) resistor equal to the feedback resistor. This network pull up the output of cap thus can not discharged due to its big value (usually from 2,2μF and above to not cut the low frequencies). If you short with a wire the out leg of cap to Gnd then is discharged and its DC offset is zeroed. Fotios |
| Ci and DC offset ?? | decky | Chip Amps | 29 | 15th February 2008 10:35 PM |
| Op amp Dc offset | legarem | Solid State | 12 | 7th February 2008 04:48 PM |
| Is there any test cd to test jitter using a scope ? | gaetan8888 | Digital Source | 4 | 10th August 2007 09:24 AM |
| 4v dc offset | xplod1236 | Chip Amps | 2 | 23rd April 2004 06:24 AM |
| GC very low DC offset | matjans | Chip Amps | 7 | 22nd September 2003 10:24 PM |
| Page generated in 0.09267 seconds (77.01% PHP - 22.99% MySQL) with 10 queries |
