Old 2nd October 2009, 10:57 AM   #1
croccodillo's Avatar
Default Yet another Push-Pull
Hai all,
I'm drawing and simulating a PP amp; it started as a Nelson Pass's Aleph Mini Clone, then evolved into an Hybrid (tube/mosfet) and now it is a full SS PP amp.
I intend to use a pair of N jfet at the input (as per Aleph Mini J), as a differential pair (or LTP).
I've seen Nelson Pass suggest 2SJ109 device, which is unfortunately not available anymore.
I'm simulating the amplifier using two BF862 device, which looks promising.
They are unfortunately available in the SOT23 package, which is not really a DIY-friendly package.
So, my question is: can you suggest me a N Jfet model, maybe in TO92 package, which can be used here, and which you like?
Of course a dual Jfet would be perfect.
Here is the schematic and LTSpice simulation (rename the txt file into a asc file).
Please check also the schematic, if you can it can be improved let me know.
Ciao,
Giovanni
In Nomine Libertatis Vincula Edificamus,
In Nomine Veritatis Mendacia Efferimus.
Old 2nd October 2009, 11:43 AM   #2
AndrewT is online now AndrewT  Scotland
I am confused.
You like Mosfets.
Do you know how and why they operate?
regards Andrew T.
Old 2nd October 2009, 12:20 PM   #3
Originally Posted by AndrewT View Post
I am confused.
You like Mosfets.
I know mosfets, yes.
Your statement means I forgot something important in my schematic?
I cannot understand what do you mean.
Please explain.
Old 2nd October 2009, 12:24 PM   #4
In the meantime I realized I posted the wrong schematic, now I'm working on the one below.
The only big difference is it uses only N channel mosfet at the output, cause I have a bag full of IRF122 devices...
6T9 push pull Jaime Tubes / Valves 2 26th December 2007 04:14 PM
An all DHT push pull amp. Eusebius Tubes / Valves 3 28th October 2006 12:37 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push-pull amp with OP piney Solid State 1 28th March 2005 02:34 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.07455 seconds (72.69% PHP - 27.31% MySQL) with 11 queries
