Dear friends,
i want to construct a highly stable , very low distortion audio power amplifier for household use in 60 to 100w range. Where i can get the circuit? Please help meledath
#2 |
You could try Rod Elliot's 60-100W power amp.
http://sound.westhost.com/project3a.htm PCBs are available for it, too. More projects here: http://sound.westhost.com/projects-1.htm |
#3 |
THANKS FOR THE COMMENTS,
IS ANY OTHER CIRCUITS USING MOSFETS AVAILABLE ? SHOULD BE REALY WORKING AND HIGHLY STABLE. |
#4 |
How about Project 101?
http://sound.westhost.com/project101.htm |
#5 |
Thanks ,
do any one have working schematics which use op-amp as input stage and mosfet o/p stage having highly stablility and ultra low distortion. All are welcome to this discussion |
#6 | |
If done correctly it may make an exemplary amplifier based on conventional measurements.
regards Andrew T. |
#7 |
THANKS ,
Waiting for comments from all experienced people. ;;;;;I DO REALY NEED A WORKING CIRCUIT. I AM AFRAID OF THE DESIGNS IN ELEKTOR. MOST OF THEM FAILS AFTER ASSEMBLING;;;;;;. |
#8 |
You can always hack together a Musical Fidelity B200.
![]() Or,if you think you're up for it, build a YAP : YAP power amp revisited, now at v2.1 |
#9 | |
Experienced person: "The ones mentioned so far in this thread work and if they are assembled CORRECTLY will not fail. "
#10 | |
i think not ... meaning that most of their amplifiers was stragles to introduce this or that technolgy but sound results were always strange ...the amplifier had this but not that and the model who that didnt had this ... and all of them together never had one of the most importand : stability under all cases ...under some cases yes under all cases ....or if all is too much let me say most then .... (I am alwoed to have my personal opinion in this ..... ) in real life in the forum one of the most popular at this range of power and plenty of support is two ( the DX amplifier and the esp P3A amplifier ) to my opinion the DX amplifier is very honnest accurate stable and also measures properly to my opinion the P3A amplifier is more musical less accurate and more nervous than the dx ( bennefits of sziklai ) also stable and doesnt measure that good next to the DX you may choose what fits you better though you need to keep in mind that terms like low distortion dont come from a schematic .... construction, pcb, wiring , psu and the total layout makes a hell of a lot of diference to achive a target like that happy regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.11319 seconds (77.22% PHP - 22.78% MySQL) with 11 queries |
