#101 |
The similarities are existing indeed, unfortunately this kind of principle seems to be invented again and again and most people (including Yamaha with their later models) make the same mistakes again and again:
- The Bias current is choosen to be rather low (Very tempting indeed to do so), which means, that the power supply lines are polluted with high amounts of overtones , not much less than equally biased Class AB. This leads into the land of layout critical circuitry and a significant rise of distortion at lower impedances (At 16 Ohms these circuits simulate very well). Unfortunately the drawbacks of choosing low bias currents were never really well addressed in such designs (Probably only on the Sony TA-N902, which has a very careful layout and rather high bias). - Some topologies like the Nelson Pass approach or Technics New Class A push the switching distortion problem from the output devices into other parts like diodes. This should then correctly called "Pseudo Class A" or "Class CA". - In most approaches the input impedance is difficult to drive at high frequencies, because capcitive or dropping local loop gain effects relativate the advantages of the theoretically almost non existing crossover distortion, so finally the problem is again pushed into preceiding stages or into the need of stellar amounts of global feedback, which is known to be difficult to achieve with low order compensation schemes ... ![]() The first one of these points Nelson Pass criticized about the so-called "Copy Cats" of his dynamic bias circuit like Technics, Yamaha, Pioneer, Denon etc. more or less for good reason. Ironically his first dynamic bias creation, the nowadays almost legendary 800A doesn't idle at very high bias as well (200W idle advertized, << 40W in real life) and it isn't by far free from the above described effects. Finally Peter Blomley probably had the right to call Nelson Pass a "Copy Cat", as he calls the "Japanese". IMO the so-called "Japanese" rather copied Blomley and Schwarz, than that they copied Pass .. Neither Masao Noro of Yamaha, nor Nelson Pass of Threshold were the inventors of dynamic biasing (Peter Blomley was it most likely, with all the potential flaws of his first circuit). Unfortunately no one really implemented it completely right to date, except Yamaha in the MX-10000, which amongst other things idles the HCA stage at 7A. Unfortunately this is only possible because it is implemented at the expense of a separate "small" power amplifier stage, which runs at +-4V ! I don't say, that this kind of circuitry is impossible to realize, but if you don't go the way of high bias currents like Yamaha did in the MX-10000, it seems rather difficult to achieve the "text book" performance in a real amplifier with real world loads,a real world layout and real world components ... ![]() This is certainly not suited for DIY ...
My amplifier is very musical: It accompanies myself on the grand piano, that's not half bad ! |
#102 |
Conclusion for me is in the meantime, that all low bias audio amps (below 100mA for the output stage) will always be different in sonic performance in comparison to pure Class-A/single ended, no matter, which topologies and error corrections are in use.
Basiclly the same how to read by the third paragraph of https://passlabs.com/articles/single-ended-class-a Also the thread Collection of Class B topologies <100mA Idle and Sound closest by Class A provides here no other findings. Additional I note by several listening tests, that there is no justification for a very effort-designed front-end topology used for a low bias output buffer. The topology by post #13 about Anybody have scan of AN-483B (Motorola)? provides best possible audible sonic quality in Class-AB. More complex circuits provides more excellent measured results (especially much lower values of THD), but from the audible view nobody hears distinct advantages (mainly through masking effects from the complex THD spectrum, generated in the output), if the quality is definitely right for the power supply of both versions. But one question is still of interest for me regarded bi/multiamping systems resp. active loudspeaker systems: below which frequency the benefits of Class A are no longer audible (I know exactly, below 300 Hz nobody can say, If there is pure Class-A or Class-AB power amp with only 30mA output bias is in use) ?? Last edited by tiefbassuebertr; 12th July 2012 at 05:09 PM. |
#103 | ||
If so , all of conventional classAB amplifier have same, or worse the problem? Quote:
then it output only distortion negating signal voltage and sink output of main amp's signal current ,isn't it? Is is need to be classA? to suppress the error of ERCO? How do you think? If its HCA OPS is conventional ClassAB and share the supply with main OPS , the supply current will not be much polluted, because it is BTL. |
#104 | |
As far as how exactly this type of dynamic bias works, I can't describe it because Spice has been unable to model it properly. All we got was distortion, yet the actual 10000 and 2000 amps make almost none. Last edited by kouiky; 30th July 2012 at 10:45 PM. |
#105 |
I have some pictures and schematics coming
#106 |
THX for info but I cannot find this US US7024028 patent.
Are you sure you get it right ? I am waiting for for the promised diagrams. |
#107 |
And maybe you know the patent number for ZDR circuit?
| Yamaha HCA circuit | jony | Solid State | 6 | 14th April 2009 04:02 PM |
| US to Euro Power Conversion for my Yamaha Keyboard | daveytree | Everything Else | 5 | 26th February 2009 12:46 AM |
| Yamaha HCA circuit. | devzero | Solid State | 3 | 20th August 2008 05:21 PM |
| TDA1541 IV Conversion - Circuit Help Needed | kblsnbts | Digital Source | 1 | 12th July 2006 08:50 PM |
