Best method(s) for testing PS caps?
Old 29th September 2009, 11:22 PM   #1
clm811 is offline clm811  United States
clm811's Avatar
Question Best method(s) for testing PS caps?
I have several large electrolytic caps I would like to try out for power supplies(for power amps), but want to verify their good condition before using, to avoid any problems(explosion, etc).
My capacitance meter only goes up to 2,000 ufd, so it's not good for this.
What are the easiest (and best) ways to check/test large electrolytic caps.
Thanks in advance!
-Chas
Old 29th September 2009, 11:49 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Thanks in advance!
-Chas
Charge them up, then discharge through a resistor while watching on a scope the decay time. From that you can work out the capacitance.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/sch/i.html?_f...nload&_sacat=0
Old 30th September 2009, 11:42 AM   #3
clm811's Avatar
Any other methods not requiring an oscilloscope?
Old 30th September 2009, 11:48 AM   #4
brig001 is offline brig001  United Kingdom
My old moving coil meter had notes in the manual for how to estimate capacitance using the ohms range. Can't remember if you noted peak needle position or timed it...
Would certainly give you a way to compare some (discharge first).
HTH,
Bri.
Old 30th September 2009, 11:49 AM   #5
On Hiatus
SY's Avatar
Voltmeter and stopwatch; using the estimated capacitance, set the time constant for about a minute, charge the caps up, then monitor the decay.
But that's only part of the story. You'll really want to check leakage current- if it's significant, the caps will be less effective, run warm, and die young.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th September 2009, 04:31 PM   #6
h_a is offline h_a  Europe
h_a's Avatar
Electrolytics only explode when voltage polarity is reversed (and exceeds 1.6V). When properly used, no need to worry.
Have fun, Hannes
Old 30th September 2009, 04:46 PM   #7
cbdb is offline cbdb  Canada
For leakage current, charge the cap and see how long it takes for the voltage to drop with no load. The ESR is also important for power caps but more complicated to measure.
Old 30th September 2009, 05:40 PM   #8
kevinkr's Avatar
Have fun, Hannes
Unfortunately, that is absolutely NOT true in my direct experience. I have had more than one do this, and in all cases the capacitor was operated well within its ratings, including voltage, ripple current, and ambient temperature. Not a huge number over the years, but enough to not summarily dismiss it as an impossibility..
The most egregious of these was a brand new CDE brand axial type, it was "violently" defective out of the box. This was about 25yrs ago, running at 65% of rated voltage, room temperature and no ripple. It physically destroyed a channel in my just completed mosfet power amplifier project - I smelled something, but by then it was way too late to prevent what happened next. The capacitor exploded, blowing the end out and destroying everything in its path - the mess extended some several feet beyond the amplifier and bench to the walls and floors of the lab where I was working. IIRC this was a 22uF/35V part with about 24V across it. (Who would have thought such a small cap could make such a big mess, but it did.. Cap had orange jacket and was about 1.25cm wide x 3.7cm long.)
It is always a good idea to test leakage current if you are unsure.
Brand new caps can be defective as received, and older caps can and do explode usually at some point (hopefully well) beyond what was considered useful end of life by the manufacturer. Ever wonder why modern caps are designed to vent "safely" - it is because these sorts of failures are statistically common over the life of the part.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 30th September 2009, 08:22 PM   #9
clm811's Avatar
Did a quick search on leakage current. lots of posts, but nothing detailing test procedure(s).
Can anyone suggest a quick and easy way to test leakage current, with no test equipment other than a voltmeter(and transformer with rectifier, of course)?
Old 30th September 2009, 08:38 PM   #10
On Hiatus
SY's Avatar
Put a resistor in series with the cap, then apply voltage. Measure the voltage drop across the resistor and that will give you leakage current. You want the applied voltage to be somewhere near the max voltage rating of the caps, and size the resistor to something like 1k, which will give you 1V per milliamp of leakage.
Best method(s) for testing PS caps?Hide this!Advertise here!
Testing PS filter caps Conrad Hoffman Parts 23 20th December 2009 03:55 PM
Amplifiers, AB comparative testing, a blind test method. destroyer X Solid State 34 29th September 2009 01:39 PM
which is better method for Thiel small parameter testing? jaya000 Multi-Way 15 13th May 2008 01:17 PM
A different speaker testing method Few Multi-Way 27 9th May 2007 03:00 AM
stupid question and strange testing method ,da pinch test fortuosity Solid State 11 7th February 2006 04:35 AM
