Hola Y'all,
I hate to admit it but I screwed up and shorted out my 12v ps while trying to figure out a VU meter problem and toasted the 12v side. This power supply has more transistors than most amplifiers. That being said I have been able to source all the affected transistors, my question is i have a 13v 500ma zener that I do not have and wonder can I use a 12v zener and fiddle with resistor to mget my 12.8v at the base of TR213/ zener is d210. I have attached the schematic (ps only as the whole thing is gynormous) Your input is valued, Elwood
"when you open your mind to the imposible, soon you will find the truth...." Last edited by eyoung; 28th September 2009 at 11:51 PM. Reason: my schematic did not load |
#2 |
whoops...
my schematic did not load... let us try again. E
"when you open your mind to the imposible, soon you will find the truth...." |
#3 |
in practice the slightly lower voltage by just using a 12v zener should make no difference to operation at all.
#4 |
Hi Elwood,
from a short look d210 is the rail voltage reference, if you use a lower zener you get a lower rail. You cannot adjust it with the resistor, as the Zener goes directly to the base. Have fun, Hannes |
#5 |
Or you could place one or two diodes in series with the zener..
#6 |
Hola Y'all...
as I am still thinking and collecting parts to repair my P/S there is a transistor that is no longer available , TR214 see previous post for schematic it is a 2sc789 and I am looking for a subtitute my best guess is either a TIP31c or a BD139 both readily available from Mouser or Digikey any thoughts on the subject would be apreciated... As I humbly Remain, Elwood
#7 |
Yup, TIP31 "B" or "C" will do the job.
#8 |
Hola again Y'all...
Thanks for the input, as they are cheap I may buy some of both. I'll keep Y'all posted.. Thanks a heap, Elwood
#9 |
If you want to keep that thing alive, get in there are replace all those horrid 2SC458 leaksistors in the +/-85V regulated supply (which the VFET's need to stay alive). I generally use Fairchild KSC945L's, but there's lots of good subs for the C458, such as the Panasonic 2SC1509S.
If the meter(s) go whacky, know up-front that it's full of those C458's. Last edited by EchoWars; 20th October 2009 at 12:29 AM. |
#10 |
Echo Wars ,
Thats just the kind of info I was looking for. Thanks a Heap, Elwood
| Yamaha AX-390 | Predator864 | Solid State | 15 | 15th July 2011 08:36 PM |
| yamaha b-2 | gdromeo | Vendor's Bazaar | 0 | 5th January 2008 03:13 AM |
| yamaha rxv 795 av amp | homertooties | Solid State | 5 | 11th August 2007 09:37 PM |
| Yamaha A-550 | angel | Solid State | 4 | 18th January 2006 01:22 AM |
| Yamaha PS-800 | sirron | Swap Meet | 0 | 3rd March 2005 04:52 PM |
| Page generated in 0.10144 seconds (76.17% PHP - 23.83% MySQL) with 11 queries |
