Old 28th September 2009, 07:37 AM   #1
salesmonster's Avatar
Default PC Case for amplifier
Has anyone used an old PC case for an amplifier enclosure? The amp intended for the enclosure will require a large-ish heatsink and cosmetics aren't important for this project. Is there a simple way to attach a heatsink to the outside sides of the case, and still have an efficient thermal transfer?
SM
Old 28th September 2009, 07:39 AM   #2
frugal-phile(tm)
planet10's Avatar
I haven't done it yet, but i have a growing number of Apple G4 & G5 tower cases that i intend to use for amps some days. The G5 cases are aluminum. The G4 cases would need to have internal sinks (or be used for tube amps)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th September 2009, 12:36 PM   #3
nigelwright7557's Avatar
SM
I have done this twice.
I used the desktop rather than the tower to keep things flat but also allow a flat top for a mixer.
The PC case can utilise its power input socket and fan mountings which is great.
I stripped out the power supply and used its mains socket.
PC cases are good and solid and make good audio enclosures.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 28th September 2009, 05:49 PM   #4
CBRworm is offline CBRworm  United States
I have considered using a small desktop PC case with fairly good front to back airflow (single 120mm quiet fan) and putting all the heat sinks inside. I could make everything much more compact - just need to make sure overtemp protection works in case of fan failure, etc.
Old 28th September 2009, 08:13 PM   #5
Make sure you use high air flow fans.
I got caught out with the small flow fans and my amp over heated.
So I put one high flow fan on the front and another on the rear of the case.
The fans with LED's insdie them look very good.
Old 28th September 2009, 09:32 PM   #6
Craig405's Avatar
PC cases could potentially be ok for an amp, just not the cheap ones, the aluminium would almost certainly bend under the weigh of heavy transformers.
As for heatsinking power transistors to the case I would have thought this is a bad idea for class A or high powered amplifiers as the aluminium is just so thin, even though theres a lot of surface area you will get big hotspots under the devices.
Mounting a heatsink to the other side of the aluminium to make it external to the insides as I believe you enquired about could improve this situation, but you end up with another thermal juncton to overcome which will reduce the heat transferred to the heatsink itself.
The best solution would be to cut away a portion of the PC case and bolt your transistors straight through to a large externally mounted heatsink, this way you get the pc case for your circuits and the advantage of good heatsinking.
And as others mentioned mounting the heatsink inside the case could also work very well if you use the ventilation and fan mounts of the case to bring enough air inside and remove it again.
Although with fans comes dust and with dust comes heat and eventually smoke
This amp will be one ugly SOB though.. no two ways about it!
With further thought actually a barebones shuttle case could offer a very nice solution as they are smaller in size, nicer to look at and most importantly come with a neat passive heatpipe cpu cooling solution integrated that can handle a fair bit of power dissipation.. with good air flow added this could be a very feasable solution.. hmm.
Old 28th September 2009, 09:37 PM   #7
hmm.
I mounted a large heatsink on the inside and blew air through it with a fan at the front and the back. But you need decent fans with a good airflow for this to work well. You could even add a third fan that blew air through the heatsink to be sure of a good flow.
Old 28th September 2009, 09:43 PM   #8
Craig405's Avatar
check this out for the shuttle thing:
http://images.google.co.uk/imgres?im...a%3DN%26um%3D1
you could drill in a good few T0220 or similar devices into the plate and use the funky heatpipe solution, all in a nice, solid, neat case.
Old 28th September 2009, 11:17 PM   #9
sandyK is offline sandyK  Australia
Default PC Case for Amplifier
http://www.siliconchip.com.au/cms/A_102322/article.html
Old 28th September 2009, 11:23 PM   #10
Originally Posted by sandyK View Post
That looks very neat.
I have built two, both in desktop cases so the large mixer goes on top neatly.
One is 600WRMS and the other 800WRMS.
Building an amplifier case Tripmaster Chip Amps 5 11th November 2008 06:32 PM
Amplifier case / housing GeeVee Swap Meet 8 4th August 2008 01:11 PM
Case (chassis) for the amplifier j3qq4 Chip Amps 0 26th July 2007 08:26 PM
Pictures of your amplifier's case Bricolo Solid State 70 24th December 2003 09:29 PM
Wow.. amplifier case. arnach Solid State 45 6th October 2002 06:06 AM
Page generated in 0.12927 seconds (79.87% PHP - 20.13% MySQL) with 10 queries
