Old 27th September 2009, 04:04 PM   #1
RS232 is online now RS232  United Kingdom
Default Pioneer A-60 fault
Hi everybody I have a small (?) problem with my wonderfull A-60
The problem is that about 40 minutes to 1 hour of playing it cutts off the speakears relay, everything else is powered but no connection to the speakers.
Can someone give me a hint were to look ?
I have the service manual
I have seached the forum and found nothing about this amp.
Ric
Old 27th September 2009, 04:21 PM   #2
eyoung is offline eyoung  Scotland
eyoung's Avatar
This is usually caused by DC on the speaker output. If you or another abliging soul could post a schematic maybe one the smart guys on the list could posit a possible cure...
Regards Y,all, Elwood
"when you open your mind to the imposible, soon you will find the truth...."
Old 27th September 2009, 04:39 PM   #3
AndrewT is online now AndrewT  Scotland
find the pins on the speaker relay that have the input signal on them.
Check the DC output offset voltage while the amp is cold, again after 15 minutes of warm up time and finally after it has shut down.
regards Andrew T.
Old 27th September 2009, 05:04 PM   #4
big jim is offline big jim  England
hi i have the service manual pm me and i will send you a copy
Old 27th September 2009, 05:23 PM   #5
Mooly's Avatar
Might be more simple than that with any luck... check for dry joints on any power transistors/regulators that run hot. Had that with a Pioneer A80 years ago.
If it is a DC fault you need to determine which channel is duff. You can connect an LED across a bridge rectifier (one for each channel) together with appropriate limiting resistor and connect to output (before the relay) and ground. Any DC fault of either polarity will illuminate the LED on the duff channel.
If it's not a dry joint then B-E junctions going intermitent open circuit are favourite
Old 27th September 2009, 06:05 PM   #6
Thanks to all
I have the service manual but thanks for the offer.
What makes me think is that it never gets hot, there are lots of ventilation holes and it only get slightly warm
Will check for dry joint for start and go on from there.
Thanks again
Ric
DVD tray fault pof@ Digital Source 2 22nd March 2009 05:20 PM
M&K Subwoofer Amp Fault, Help Anyone? GES1407 Chip Amps 16 7th August 2008 07:02 PM
Pre amp fault Addolff Parts 4 6th January 2008 01:55 PM
nad 304 annoying fault sollerbeen Solid State 14 17th November 2006 06:51 PM
pioneer dv737 fault curlybill Digital Source 5 19th September 2006 02:05 AM
Page generated in 0.08308 seconds (73.86% PHP - 26.14% MySQL) with 10 queries
