Old 26th September 2009, 10:58 AM   #11
theAnonymous1's Avatar
Originally Posted by AndrewT View Post
if you can remember that
I = V / R - Ohm's law
and that
P = I * V
then all the others follow exactly from those two equations.
No reason to be either lazy nor stupid.
But frequent repetition may well be required to commit this to permanent memory, for it to stick. Just like a PC:- RAM is volatile and HDD can be almost permanent, if we know where the index to the library/files is kept.
My memory is extremely volatile.
It took a long time to get this image burned into my EEPROM.....
"If you don't like funerals don't kick sand in ninja's face."
Old 26th September 2009, 12:17 PM   #12
Nico Ras's Avatar
The formula is:
P[RMS] = Ec^2/(8*Rl) where:
P is the RMS power in watts
Ec is the supply voltage. In your case, is either 10V or +/-5V=10V (same thing)
Rl=Load resistance in ohms.
In your case, the RMS power is 10^2/(8 * 10) = 1.25W
There exists no such thing as RMS watt
Old 26th September 2009, 03:35 PM   #13
wwenze is offline wwenze  Singapore
Strange, I had P = V * I etched into my brain since I was a child. Must be my father showing me the utility bill.
Old 26th September 2009, 06:02 PM   #14
yes that's what it says.
P=I*E
I=P/E
E=P/I
where
P=power
I=rms current
E=rms voltage
regards Andrew T.
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 06:18 PM
Reducing voltage of TL494 based supply? theAnonymous1 Power Supplies 27 31st July 2007 06:34 PM
Diodes on power supply output for voltage drop? bst Tubes / Valves 7 12th July 2007 04:54 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
tailor output voltage of power supply Evaas Solid State 15 28th April 2001 07:55 PM
Page generated in 0.11128 seconds (74.33% PHP - 25.67% MySQL) with 11 queries
