Hi to all,
I built a few succesfull se tube amplifiers with EL34, GM70 and 833 tubes. Now, i am planning to built a single ended paralel mosfet amplifier. Actualy i don`t know exactly how they are sounding. Some diyers wrotes on the internet that; their sound are very very good, very warm and very closer to the se tube amplifiers especially with second harmonics. At this point, i am wondering why the famous companies did not produced such se mosfet amplifiers? Why are they not popular? Do you have any comment? Thanks a lot |
#2 | |
They are expensive in regard to components. They are OK at low powers but become unattractive in cost at higher power levels.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Go and look in the Pass Labs forum - lots of Se mosfet amps. check out the Zen amplifiers.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#4 |
Thank you very much for your reply. I am agree with you but, set tube amplifiers are the same, very inefficient (about 20-25% of the power dissipation), very expensive but also very popular. Their interstage and output airgapped transformers are difficult to build and very highly cost. Mosfet amps are simplier, easy to paralelling of mosfet to get more power. Question is remained: Why the mosfet se amps are not popular like set amps???
Thank you! |
#5 | |
Noyan |
#6 | |
Maybe the appeal is too narrow to make a good business case ? Big class A amps are relatively heavy and expensive, the more so as the efficiency of an amplifier drops and power level increases. With mosfets people expect higher power levels than from a tube SET (otherwise why not buy a triode SET instead). The additional cost of a few extra parts is a small increment over the cost of all these other items (heatsinks, power supply, chasis, marketing, overhead) and therefore it's rather tempting to improve efficiency, reduce distortion, extend damping factor and frequency response by adding circuitry. DIY has different drivers, fertile ground for simple MOSFET amps.
#7 | |
Here is the thread where I describe step by step how I build one prototype of such an amp: Wavebourn Tower-III High-end hybrid amp
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#8 | |
Most listeners aren't really audiophiles and wouldn't recognize good sound because they've never heard it before, and if you offend the taste of the connoisseur, who the hell cares? They're a minority anyway. That's why forums like this one exist: for those who aren't satisfied with "good enough". |
| Mosfet Amplifier | Telnet100 | Solid State | 3 | 20th May 2012 09:37 PM |
| MOSFET amplifier | ash_dac | Solid State | 6 | 5th December 2006 08:55 AM |
| MOSFET/MOSFET amplifier | jarek | Pass Labs | 21 | 22nd June 2004 05:04 PM |
| 1kW MOSFET amplifier | Kilowatt | Solid State | 207 | 28th March 2004 09:44 PM |
| Page generated in 0.11508 seconds (76.88% PHP - 23.12% MySQL) with 10 queries |
