Attention car amp geeks! PPI PC-2150 got it with some heat damage on the batt (+) side of the power plug ( melted plastic ). Amp saw some hard use or poor power supply. Tested it with mutimeter and test tone cd (1khz ) and one channel has 11% les AC voltage than the other using a CDA-7995 at volume 15. I inverted the RCA's to make sure it wasn't the deck. I opened it up and found a blown gate resistor on one bank of fet's. Changed the fet and resistor and repair held up. There was an improvement in overall performance but the 11% diff remained. Using Green Day's Americon idiot at the same volume setting my cheapie Jensen 6X9"s ( amp at 1/2 gain ) were stressed. I cannot hear a difference in volume between the two channels ( probably because i'm old and half deaf ) but it's a much larger difference than I've seen in other amps with a single gain. I have several other PPI's and the diff is usually about 2% or 3%. No other visible damage in the amp and all fet's and bjt's check out similar on the board. Any ideas? Thanks, Ace
ab |
#2 |
You are measuring HF oscillations, that's why a gate stopper was burnt.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Quad II power amps......power output transformers!!! | bwes87 | Tubes / Valves | 3 | 10th September 2008 02:20 AM |
| Output power VS Peak output power | Nordic | Chip Amps | 5 | 25th September 2005 05:08 AM |
| power output higher than power supply...How? | loonatron | Analogue Source | 9 | 24th March 2005 07:04 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.06756 seconds (65.14% PHP - 34.86% MySQL) with 10 queries |
