I'd appreciate any comments on the design.Thank you in advance.
#2 |
I get the impression it might be a RIAA amp with gain.
Tell us what it is and what it is supposed to do. It needs a buffer with gain before the RIAA EQ stage.
regards Andrew T. |
#3 |
Battery powered amplifier using 2x12v battery.Power 5w.
#4 |
I hope this helps:
Battery driven Pre- and Poweramp (1991/92) Features: Preamp designed for MC cartridges (Denon® DL103, EMT® TSD15, etc.) Each amp driven by it's own pair of 12V/6AH sealed lead type of accumulator Shunt-voltage-regulator to produce 11.5V for preamp and voltage amplifier section of poweramp Power amplifier produces 4~5Watt @ 8 Ohm (comparable to single ended 2A3 or WE300B tube power amplifiers) High efficiency speakers required (Lowther, Goodmans, Triangle, Roiene, etc. are highly recommended) Charger circuit included This design clearly reveals the advantages of battery driven amplifier circuits. Even they do not use sophisticated parts they do provide great sound due to the nature of the power supply. I am aware that most people are not using one of the speakers mentioned above. But in general these amplifiers are showing how far you can go with a simple circuit design combined with high efficiency speakers. The original Hitachi® MOSFETs 2SK135/2SJ50 I have used are hard to find now. But there are a few good replacements some even using the original specifications: ECF 10N16/10P16 (TO3) available from Profusion PLC BUZ900/BUZ905 (TO3) from Farnell 2SK1058/2SJ162 (TOP3) from Hitachi |
#5 |
I am sorry for my BAD English.its hard for me to write and explain.please give your opinions about the circuit.is it worth bilding something like dis.sorry again and best of luck to all.
| Comments please on this I/V amp | georgehifi | Digital Source | 9 | 11th April 2008 02:12 PM |
| X-over Comments & Help | GOWA | Multi-Way | 23 | 20th March 2008 01:09 AM |
| Please comments | vAD | Solid State | 58 | 28th March 2007 08:17 PM |
| Would appreciate comments... | TonyDasilva | Digital Source | 2 | 11th August 2005 06:50 PM |
| Comments on 71a PP Pre-amp | RichardJones | Tubes / Valves | 33 | 11th April 2003 08:22 PM |
| Page generated in 0.08658 seconds (72.85% PHP - 27.15% MySQL) with 11 queries |
