Old 23rd September 2009, 02:30 AM   #1
Default Help me build my first diy amp!
hello, i'm a novice speaker builder whose decided to jump into the diy amp scene after pulling the trigger on this kit last night. http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_6241wt_939
to power these babies that i'm currently working on the cabinets for
http://www.madisound.com/catalog/pro...oducts_id=8644
i confess i know nothing about building amps but more than eager to start out right away if you guys would help me and point me to the right direction. i've already asked the ebay seller this but... what should i purchase next? i know i want a shunt regulator from the seller's suggestion and rca inputs for pairing with an external preamp but beyond that i'm clueless. any help is appreciated. thank you in advance.
Old 24th September 2009, 07:01 AM   #2
Mooly's Avatar
I know you have to start somewhere but don't you think this is a bit ambitious for a first project.
The amp in your link makes things more difficult because it requires two different voltage rails (officially) which means two transformers for the PSU or a single one giving -/+45volts for the outputs and perhaps (depending how much current the driver stage requires) using a voltage doubler and regulator to derive the -/+60volts.
Getting it all to just work is one thing... doing correctly (wiring and so on) so that it performs properly is something else.
First DIY build - bit of help DanielD Multi-Way 10 23rd October 2007 10:32 AM
first diy build rv1890 Multi-Way 3 10th May 2006 08:11 PM
still build...just a lil more help rv1890 Multi-Way 1 22nd January 2006 10:06 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Page generated in 0.06969 seconds (66.99% PHP - 33.01% MySQL) with 10 queries
