Old 22nd September 2009, 09:09 AM   #1
Default selection of output power tr
for my amplifier with +/- 60v power supply, may i use 100v rating power tr, or the higer voltage rating the better?
thanks
Old 22nd September 2009, 10:30 AM   #2
sakis is offline sakis  Greece
sakis's Avatar
is not enough ....wise would be to use 160 volt devices each device will see almost 120 volt at some times ....so yes 100 volt is not enough
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd September 2009, 04:01 AM   #3
as i have the 100v rating power trs, are they safe if in amps with +/- 50 volt supply?
thanks
Old 23rd September 2009, 04:45 AM   #4
100 V AC rectified gives 141 V DC, i.e. +/- 70v
for +/- 60V DC you'll need a transformer that is 42-0-42 V ac
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 23rd September 2009, 07:30 AM   #5
soory i have lots of 100v rating power transister pairs(npn and pnp),
are they safe in power amplifiers with +/- 50v dc supply?
thanks
Old 23rd September 2009, 07:39 AM   #6
ostripper's Avatar
Properly derated , 100V devices would be best for no more than a 35-0-35v DC supply (might survive 40-0-40VDC). DX amp , symasym , most of the 50-60 watt amps , even a P3a (elliot sound - esp) might be best. If they are small (to-220) , you might need 2 pair at OP. i f they are big (to-3 metal) ,1 pair will do.
OS
Old 23rd September 2009, 07:49 AM   #7
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
thanks
100V rating means that they have higher than 100V break-down voltage collector-base and collector-emitter. How much you don't know; you know that more than 100V. May be much more!
To test them you can use some 300V power supply, one 300K 2W resistor, and a high ohm input voltmeter.
Collect base and emitter together, and apply voltage to collector through the 300K resistor. Measure voltage between collector and emitter. It is a rough method, but it should work well for modern transistors that have low inverse currents.
Such a way you will get real breakdown voltage of each of your transistors. Select some with higher voltages, and be happy!
+/-50V power supply can give more, depending on power conditions in your outlet. For safety I would use transistors with 120V break-down voltages at least.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 23rd September 2009, 12:07 PM   #8
wg_ski is offline wg_ski  United States
Second-breakdown ratings are uncertain, however. If you do this be conservative. If the original design calls for two parallel pairs, use three. Or four. If you already have them, you won't be out anything but some inexpensive emitter resistors.
Old 25th September 2009, 09:22 AM   #9
as the origial design use bdv64c/65c darlington trs,as they are difficult to source nowaday
please suggest newer devices to replace
thanks
Old 25th September 2009, 09:28 AM   #10
sakis's Avatar
since darligtons is a quiet strange story for starts i could advice you to trush the design and work with something better
serch the forum for a post called "a darling....ton story " there you will find plenty of info regarding designs based on these devices
though there is many other posts related to this ....read carefully and then decide if you like to play arround this devices
your first option will be ON SEMI 11015-16 extremelly rowbust allready been working in Marshal amplifiers but packadge might be a problem TO3
kind regards sakis
PS if your concept is to push the amplifier by lifting the rails higher for more power just skip it it will never work
Input selection and volume control with balanced output, transportable? jmaurer Solid State 0 11th August 2007 07:08 AM
6G15 output transformer selection layt Tubes / Valves 0 2nd July 2006 12:55 AM
Power transformer selection madness photo_marc Tubes / Valves 2 16th August 2005 02:43 AM
Newbie Q: Amp selection for high power/low Z AtomicDog Pass Labs 12 26th July 2005 09:33 AM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Page generated in 0.12081 seconds (79.47% PHP - 20.53% MySQL) with 10 queries
