Hi everybody
i have a 120W +/- 38V regulated power supply (measured without load) which i would like to use for a power amplifier. Any suggestions about the amp to use with? i'm looking for something reasonably cheap to build (no gainclone, since i already have one...) Can i use it to power a pass F3? thanks a lot |
#2 | |
#3 |
hi,
if this is an SMPS then it will power a low wattage power amp badly. It may power an preamp but the pre-amp must be designed to run at that voltage.
regards Andrew T. |
#4 |
well, so far this power supply has been used with a single tda7294 chip (wich can deliver 100W), following the application note in the datasheet, so i guess it can be used for an audio amplifier...
120W it's the rating of the the toroidal tranformer. I don't know actually (but i will check) the current rating of the linear regulator. It is not a smps. |
#5 |
I try to collect old power supplies for future amp building too ! - it would be good to know more about the psu you have.
If it's a linear power supply (big transformer and big capacitors) then you may want to rebuild it (replace old caps, add filtering, quieter rectifier etc.). I'll assume you have a linear power supply. I'll assume that the trafo is 120VA with two 25V a.c. secondaries (yes, a rather cavalier assumption). This gives you three options, a) single pair of split rails +/-38V each capable of at least 2A, which when divided between L & R channels gives not very much. This is the last preferred option. If you have a transformer with only one secondary and no centre tap it's your only option though. b) if you re-wire to create a single supply (you can do this so long as the transformer has two secondaries or a single centre-tapped secondary). single rail supply +38V capable of at least 2A into each of L & R channel amplifier. This should allow you to build a Zen amplifier (F2?), you don't have to run it at the full 2A idle current, cut it down to around 1.4A. c) if the trafo has two secondaries you can generate two pairs of split rails of roughly +/- 19V each capable of at least 2A This option allows you to use a different secondary for the Left Channel and the Right channel should you want that kind of separation. You'll be flowing 2A through 8 Ohm speakers giving a +/-16V swing. My ignorant guess is that this would work best with a ClassAB amplifier which can get pretty close to the power supply rails. There are simple ClassAB amps you can build - look at Rod Elliot projects and Carlos' DX amp. p.s. just saw your post - good, it's a linear supply !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#6 |
thanks, i will check how my trafo is actually made.
later i will let you know which will be the destiny of this PSU! |
#7 |
I checked the trafo. it has two independent secondaries capable of providing 28 V ac each.
so i think i will go for option b. i will run some pspice simulation to see if i can use it for an F2 amp wich runs at 1.4 a for each channel. again, thank you very much! |
| DYNACO 120W AMP for DYNA A-451 | edrel sison | Tubes / Valves | 32 | 26th January 2011 02:24 AM |
| Laptop 90W-120W? | di4kata | Power Supplies | 13 | 4th May 2006 01:22 PM |
| 120W MOSFET amp. | Lamicz | Solid State | 8 | 26th January 2006 04:37 PM |
| Output from Shiva with 120w? | nrgy | Subwoofers | 2 | 12th November 2004 12:18 PM |
| 120W Mosfet amp modules | Peter Daniel | Swap Meet | 7 | 14th November 2003 12:27 AM |
| Page generated in 0.10909 seconds (76.20% PHP - 23.80% MySQL) with 10 queries |
