Old 21st September 2009, 01:57 PM   #1
mckvak is offline mckvak  Czech Republic
Default passive correction preamp.
Hi all I need for my project praemplifier. I decidet for passive correction preamp, BUT I will need help. I will be very pleasant, if will someone show me the schematic and make clear how it work.
Sorry for my english I know itīs a horrible as you see I am new here.
Old 21st September 2009, 03:09 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Ehhh... What kind of correction do you need?
jd
/Another new issue: Linear Audio Volume 3!
Old 21st September 2009, 04:21 PM   #3
jd
I need bass and treble.
Old 21st September 2009, 05:13 PM   #4
janneman's Avatar
OK, but that means it will not be a passive preamp, you will need some active gain/buffer stages.
Edit: in theory, a passive system is possible, but its characteristics will be very sensitive to the source- and load-impedance.
jd
Old 21st September 2009, 05:27 PM   #5
jd
So what do you suggest
Old 21st September 2009, 05:34 PM   #6
janneman's Avatar
The simplest, most used tone control is the one designed by the late Peter Baxandall. Google is your friend
For instance: http://sound.westhost.com/dwopa2.htm#baxandall
jd
Old 21st September 2009, 05:36 PM   #7
jd
It look fine
Old 23rd September 2009, 03:59 PM   #8
janneman's Avatar
It look fine
Thank you too.
jd
Passive preamp? Skorpio Solid State 10 22nd May 2008 06:17 PM
Passive correction for SPL dip? Tenson Multi-Way 20 8th May 2007 05:20 AM
Want a passive Preamp hkfind Swap Meet 0 5th January 2006 07:07 AM
passive preamp digi01 Chip Amps 4 8th February 2005 05:37 PM
Passive Preamp Hum transducer Solid State 11 16th November 2002 03:51 AM
Page generated in 0.09905 seconds (75.94% PHP - 24.06% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
