Hey all,
I'm having trouble biasing my ST-140. Prelude, I've rebuilt a Sansui au-999 and others so I kinda know my way around. I have the schematics As per the instructions I got from B&K remove the + rail fuse attach dvm set to milliamps (fluke77) adjust p2 to 200 milliamps. On one channel I can't adjust it past 35ma, the other just pegs the meter to OL then drops after power off. ![]() This happened on the 999 and I had to replace the driver tranistor, is this the same deal? BTW the amp plays fine and sounds good, I just want to make sure it's in spec. and not about to blow the outputs, as they are Unobtainium (I replaced them about 12 years ago). thanks. mdr |
#2 |
Post a schematic of the output and bias chain?
#3 |
#4 |
the bias is controlled by the voltage dropped across P2 by the current set by the constant current source consisting of Q10/R9/the LED
so check those parts and voltages on them. I'd say compare channels but it sounds like both channels are wrong, still it can't hurt to compare oh and other things could cause your problem, output MOSFETS for one |
#5 |
Thanks I'll check those.
mdr |
#6 |
OOOPS.
![]() I had the probes in the wrong holes on the meter Everything works great now ![]() I'm going to be re-caping this guy any way. I'll post with results. thanks again. mdr |
#7 |
Cool!
I have a st-140 too, but never messed with it. I get an occasional rustling noise in one channel, so I was thinking to recap it too. It seems to use some sort of Arcolytic nonpolar caps. What are those, some obsolete brand? Last edited by jackies; 24th September 2009 at 02:59 PM. |
#8 |
What you see is what I got.
#9 |
This is an old thread, but I was hoping to see if you ever recapped your ST-140. I have one also and am considering some refresh work.
Brian |
#10 |
Hi, Does anyone happen to know where the test points are for setting the bias with this amp are? Thanks.
| Trying to salvage a B&K ST140 | jwv3 | Solid State | 4 | 15th January 2009 11:23 PM |
| Trouble with unstable bias setting. | ppfred | Solid State | 7 | 3rd January 2006 01:15 PM |
| p3a bias trouble, quick question :) | Mattyo5 | Solid State | 13 | 13th May 2004 08:03 PM |
| bias trouble in pnp output stage | Easyamp | Solid State | 5 | 17th December 2003 06:36 PM |
| Page generated in 0.09975 seconds (77.28% PHP - 22.72% MySQL) with 10 queries |
