Old 19th September 2009, 08:59 PM   #1
vtech is offline vtech  Czech Republic
Default Class-A BiAmp - my first design
This is my first design. It's the Class-A BiAmp. SPICE doesn't protest. It seems to work, but I've got no idea, if it really works. What do you think?
The powersupply is an industry standard regulated stabilized 24V/10A.
Old 20th September 2009, 08:14 AM   #2
destroyer X's Avatar
Default I think you already know that in normal music with have a proportion, a ratio.
60 percent of power goes to bass
30 percent of power goes to midranges
10 percent of power goes to treble
This is what we see into the musical waveform...that's the ratio we love (of course this is not precise..numbers can change depending musical style, taste, culture, ambience and so on).
We see into tree way speaker, and i have expertise in the learning dismounting and observing things, they use that ratio into woofer power, midrange power and tweeter power.... and they do this way to save money and increase profit.
So, if we have this ratio, i suggest you, to increase power into the bass amplifier or to decrease power into the treble...yeah!..you can just reduce volume, for sure you can reduce treble volume...BUT.... reducing power, or accepting that, you can use class A to treble, where the class A may need a very small crossover distortion...really, to bass, not so needed.
This way... class AB to woofer is more often used, as efficiency is bigger and the power produced is higher.
I am also doing this way.... and adjusting...and soon i will open a thread to post my thougths about.
here you have a sample...what i am still doing..adjusting using ears...try and error basis.... it is turning very, very, very good..soon will be excelent.... just more hours of very hard work and will be ready.... they are in inverse order..the first one is the last video made...so..the most evoluted one,but not the final one.... the last one was the starting of this job using that speaker enclosure.
http://www.youtube.com/watch?v=Aybx2UVWtQ4
http://www.youtube.com/watch?v=Ew7Sr1IA6h8
http://www.youtube.com/watch?v=q5NVcpmoVaQ
http://www.youtube.com/watch?v=rljMY96z13M
http://www.youtube.com/watch?v=cPqXEd1U6DM
Try to build an amplifier folks ... it is pure adrenaline!
Last edited by destroyer X; 20th September 2009 at 08:22 AM. Reason: I could not correct post title..it is wrong written
Old 20th September 2009, 09:33 AM   #3
Thank you for your reply.
Yes, I know about this. I've even spent some time analyzing my favourite recordings. I just wanted to keep the design simple.
I'll push the split frequency as low as the tweeter (not chosen yet) allows to balance the load as much as possible.
I'll check your videos.
Old 20th September 2009, 03:14 PM   #4
Default Very good..i am also working on BiAmp
regards,
Carlos
Old 20th September 2009, 05:33 PM   #5
Default update
I have updated the design.
Band is split at cca 2100Hz. I'm going to use 1800-22000 tweeter.
Now I'll try to build it.
Old 20th September 2009, 08:16 PM   #6
Last update (I hope).
Crossover frequency is now down to 366Hz.
I've changed my mind regarding speakers. I'm going to use full range + bass speaker.
New Class D design peranders Class D 8 9th October 2007 07:51 AM
Hybrid Class A / Class B design. GK Solid State 27 1st January 2007 02:30 AM
class d design oldroborg Class D 18 19th December 2005 12:32 PM
To Biamp or not to Biamp, that is the question??????? Apogee Pass Labs 70 12th July 2002 12:34 AM
Page generated in 0.08667 seconds (76.45% PHP - 23.55% MySQL) with 10 queries
