I want to test compression driver for 50W sinewave.
I will give 1 khz sinewave input from PC. How to set amplifier output level for 50W/100W @ 8 ohms with multimeter? |
#2 |
50W into 8r0 is the same as 20Vac into 8r0.
100W into 8r0 is the same as 28.28Vac into 8r0. A compression driver is unlikely o be rated for a continuous 50W of input. They are used to seeing a few milliseconds of input at the higher voltage levels and sustained power about 10 to 20dB below the maximum rating. 1kHz and 28.29Vac (=40Vpk) may take your compression driver way past it's Xmax and even past it's Xmech!!!!
regards Andrew T. |
#3 |
It is to test protection circuit without amplifier connection to compression driver.
I will use 8 ohm resistor as load. The 50W/100W will hv to be passed through -4.5db L pad, -18db crossover & then protection circuit with PTC & resistor+ bulb in parallel. So want to set the amplifier output to check the circuit. Any other suggestion will be appreciated. |
#4 |
Did it Himself
You don't need 8 ohm resistor load, just set amp to voltages as Andrew has told you.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
I am not going to put resistor as a load to amplifier.
But i will put resistor as a load to the protection circuit. Amplifier output will be used as input to the protection circuit. |
| Power Amplifier Output Topologies | danville | Solid State | 58 | 7th March 2010 05:40 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Power Amplifier Output Protection | kosalev | Solid State | 2 | 16th November 2007 11:39 AM |
| JL Audio amp - setting input level | S54_addict | Car Audio | 4 | 20th April 2006 05:34 PM |
| Want to convert amplifier output to input level | rkc7 | Everything Else | 1 | 16th May 2004 10:19 AM |
| Page generated in 0.08604 seconds (74.56% PHP - 25.44% MySQL) with 10 queries |
