#11 |
Did it Himself
Here you go. Thinking about it a bit more as I was drawing it I think you don't need any extra resistors to get clean switching as the amps input will never have its input broken away from being able to source current.
![]() Use a DPDT switch, the top half shown above is the normally closed ones and the bottom/right is the normally open ones. The only downside to this is you would either need two switches or a quad gang one to switch stereo passively. If you used relays to switch the signal then you could still use the one switch but you would obviously then need a battery or power to run the unit.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#12 |
Cheers Richie!
Looks simple enough, I suppose the only thing to do is try it and see if it is quiet. The only downside is that I need the switch to be a foot operated device and DPDT seems quite rare in foot operated components, SPDT is the more common. My ideal would be a momentary action switch with the electronics providing the latch, but this would mean more complexity Ray |
#13 |
use the footswitch to pull in or release a dpdt relay.
#14 |
Did it Himself
Alternatively if you only need it to reduce the signal level not totally kill it, it can be done with one (SPDT) switch.
#15 |
Hi
Thanks for your replies. I would like if possible to reduce it to point where it couldn't be heard rather than just reduce the volume. Andy's idea of a small DPDT relay could be a good idea as I could aslo add an LED to indicate the swtiches state easily. I am just uncertain if the resistor switching can be relied on not to click or pop during switch in and out. I will need to try a few experiments to see. Cheers Ray |
#16 | |
Tried it on a breadboard with a 2N5088 and worked well for line level mute ![]() Cheers! |
#17 |
Thanks Geek
I tried this circuit attached based on a transistor I have knocking about and it seems to work quite well and I get at least -50dB reduction in volume. Is this what you mean? The 2.2K series resistor is about as high as I want to go as I want to feed a 20K amplifier line input. Not sure if I have suitable values for the R-C components in the transistor base, or indeed if I have the R-C bit configured correctly. Can you experts give me any pointers here? Cheers Ray |
#18 |
Did it Himself
The resistor is not switched in or out, the signal path is never broken, so there will be no pop or click.
#19 | |||
Hi Ray,
![]() That's pretty much the circuit, yes. Quote:
Maybe an opamp follower/linedriver (balanced for DC, hence no thump) if you want to get fancy? Cheers! |
#20 |
Old thread, but looking at the same subject
![]() I'm working on a turn on / turn off circuit for Op-Amp's, working with a fet as a shunt switch on the op-amp's output I want it to work on the regulated supply lines directly and not sensing on AC lines. The output shut be shunted until the supply line has reached say 80% At turn off is should react as fast as possible Found a good inspiration here Class-A power amplifier project - Current-Drive - The Natural Way of Loudspeaker Operation ... and worked a bit further on it. Not sure whether I need to do more with the gate circuit .... any ideas? Guess j108 would be an ok choise for this application. V2 simulates the negative supply line and V4 is the signal coming out of the op-amp Any thoughts on this circuit?? Thanks in advance, Baldin |
| Quick mute switch query.. | jethdub | Chip Amps | 3 | 19th April 2008 11:08 PM |
| How quiet is dead quiet? | pchw | Tubes / Valves | 36 | 22nd November 2007 04:36 AM |
| Help on Preamp Mute Switch | BillyF | Tubes / Valves | 6 | 6th September 2004 12:05 AM |
| Looking for a PDA car audio mute circuit | Franklin | Car Audio | 3 | 10th June 2004 05:47 PM |
| please help - no mute but did mute mod - tda1541 | loomis | Digital Source | 1 | 14th November 2002 10:54 AM |
