Old 16th September 2009, 02:44 PM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default 4560/5532 quick one
going from 4560 to 5532 will it work better ???
in a cd player i tryied ther was marginal improvement
any sugestion between the two ???
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 16th September 2009, 02:51 PM   #2
ashok's Avatar
The 4560 is a newer low cost chip I think. What difference did you find ?
I find the 5532 works very well in some designs.
I think it finally really depends on which sound " you" prefer. The 4580 is used in many ~$150/- add on high quality sound cards. The 4560 came before that. 5532's are still used by many people.
The 5532 can run at a higher supply voltage , has higher slew rate and has slightly lower noise than the 4560. I don't know the distortion spectrum of the 4560 but the 5532 seems to compare very favourably with many modern chips like the OPA2134 etc.
AM
Old 16th September 2009, 02:59 PM   #3
PMA is offline PMA  Europe
PMA's Avatar
5532 sounds "better", but do not expect any miracles.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 16th September 2009, 03:37 PM   #4
sakis's Avatar
that was my impression too but i wanted to verify with others also thanks PMA
changed them in aCD player it sounded quiet a lot better
changed in volume control of a hafler 945 tuner preamplifier and the bennefit was very low .....
a terrible device this hafler PREAMP ..... very noisy ancient input selectors a hell of a crosstalk between inputs ....i was actually amazed was expecting more from it
thanks
Old 16th September 2009, 04:11 PM   #5
AndrewT is online now AndrewT  Scotland
fit a discrete opamp or buffer if there is 0gain.
regards Andrew T.
better buffer then 5532 wleediy Digital Source 5 2nd February 2008 01:53 PM
TL072 vs. 4560? kubeek Parts 8 14th July 2006 07:42 PM
BA 4560 replaced by AD 8610 sippo Solid State 1 30th November 2005 08:40 PM
Suitable drivers for JBL 4560 cabinets steve hawkins Multi-Way 6 11th September 2005 10:58 AM
5532 preamp help enter Chip Amps 4 29th July 2005 02:24 PM
Page generated in 0.08067 seconds (75.75% PHP - 24.25% MySQL) with 10 queries
