I'm still in the parts collection stage, but still up in the air regarding which of these designs to build. Can anyone offer subjective opinion on these designs? The JLH looks nice and uses 4 output devices so I would assume it dissipates heat a bit better. Plus it uses TO-3 devices which my sinks are already tapped for.
Le Monstre looks simpler, and I can alter my sinks to use the 2SC5200s. It claims 58w into 8 ohms rms while the JLH is only 28w into 8 ohms, but will double into 4 ohms at 56w. What design would you guys reccommend? What are your impressions of the sound quality of these designs? Thanks for any information on these! Also, what size transformer is reccommended for these? Blair |
#2 |
I wonder what your needs are for power - what kind of speakers (impedance, sensitivity) and how loud you want to go. I suspect that 28W is plenty of power for your needs and shouldn't be a factor in choosing between these options. Power dissipation might be a factor, the lower power of the JLH means less heat-sinking. I haven't heard either amplifier, but I have read many consistent good reports on the JLH and it would be my choice if I had to make it.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 |
Thank you! The JLH is the one I am more apt to build. Depending on what speakers I'm using they range from 4-8 ohm and are typically 87-90db efficient. I have used SET amps in my system many times and they are just shy of what I need in power at 12w. I purchased 80,000uf of capacitance during lunch along with TO-3 sockets and mica spacers. This should get me started on the layout for the monoblocks.
Thanks again! Blair |
#4 |
I'd be interesting to follow your progress. I've recently become a lot more interested in Class A amplifiers. I may start with something very simple (e.g. a single output transistor) to get my feet wet but if that turns out I'll be taking a good look at the JLH myself.
Your speaker sensitivity sounds fine. I'm not sure how well particular amps cope with 4ohm loads, but you have a chance to design to suit (e.g. more current flow perhaps) if you feel it needs it. p.s. I discovered that you might be able to get a pcb: http://skycoral.com/1/?p=23
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 16th September 2009 at 08:57 PM. |
#5 |
http://http://cgi.ebay.com/ws/eBayIS...m=320390377484
I wonder if that board is better than this one. Thanks for the link! Blair |
#6 |
that link doesn't seem to be working ?
If you compare the design of JLH with Rod Elliot's DOZ amp perhaps you can also repurpose the DOZ pcb ?
#7 |
#8 |
#9 |
It says in the JLH article that this is the case on 22v rails. Is the article mistaken?
Would you care to elaborate? Blair |
#10 |
Hi deicde67, I do believe you are mistaken about the le monster it's output is ~7 watts
per channel. |
| Le class A and Le monstre parts sell off | danieljw | Swap Meet | 22 | 5th June 2010 09:27 AM |
| parallel Class AB amp? | h3ad | Solid State | 22 | 23rd November 2007 12:48 PM |
| Le Monstre | MikeW | Solid State | 22 | 15th May 2004 09:26 AM |
| pi filter in class a amp: okay to parallel inductors? | jwb | Solid State | 6 | 20th October 2002 07:56 PM |
| Page generated in 0.11587 seconds (80.37% PHP - 19.63% MySQL) with 11 queries |
