Old 15th September 2009, 08:13 AM   #1
Abob89 is offline Abob89  United States
Default Blown MOSFET
I have a Blown MOSFET in an old school Rockford Fosgate Punch 200a2 (the black and grind or BBQ Rockford amp if that means anything to you guys), the component is blown out at the source terminal. Now upon the inspection of a few other threads with similar FET related issues I can deduce that the MOSFET in and of itself may not be the problem, in many cases another component's anomilies may be the underlying issue. If that is indeed what I am dealing with, then how can I find the problem if there actually is one.
The MOSFET in question is Q8 on the board, Seimens Sipmos BUZ103. Another DIY'er has been so gracious as to provide me with the component's tech sheet.
http://www.datasheetcatalog.org/data...ens/BUZ103.pdf
Any help that can be provided would be greatly appreciated.
Thanks to all,
Aaron
Old 26th September 2009, 06:32 AM   #2
you will probably get a lot more help if you have this thread moved to the car audio section.
there are quite a few people that are in there that can help.
i have a 360a2 with a few problems that i have to fix.
Test for blown body-diode in mosfet? h_a Solid State 2 29th June 2009 07:47 AM
Blown MOSFET Chips -Pics- nfueston Chip Amps 7 20th June 2009 05:31 PM
Mosfet blown all the time. Matthewong Car Audio 8 2nd October 2006 07:01 AM
Simple check to see if mosfet are blown or ok? Optical Solid State 3 14th October 2004 07:58 AM
Page generated in 0.08313 seconds (71.68% PHP - 28.32% MySQL) with 10 queries
