there has been an extensive discussion regarding VI limmiters and related applications in high power amplifiers .
one of the points was this idea of mine to use an smps pick up coil as a sensor from the output to drive transistors to limmit the drivers of the amp. the idea was simple but very wery wrong since smps coils cannot be used for audio signals since the behaviour of the coil is not linear at all versus frequency since i have so many smps pick up coils i thought about design of a circuit that will see how many amps are drawn from the power supply (at DC conditions ,what the coil was originally designed for and also monitoring bothrails ) and then limit the input or the drivers with this creteria any opinion ???
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
bre anyone ????
nobody thinks that this is a possible idea ???
#3 |
current transformers have a low frequency corner – maybe it would miss low frequency Audio or a DC fault
for "DC" apps you can get Hall effect or GMR sensors that measure the magnetic field around a conductor with very little effect on the signal |
#4 | |
dc fault is another story
#5 | |
But there is a more important issue. If you only look at the (Ic or Ids) current, your amp is not well protected. If you check up on 'Safe Area Operation' you will find that the allowed power before the output devices explode, varies with Vce (or Vds). So you musty check I, and V and find a (non-lineair) curve of what is allowed and what not. There's some info on that on my website. jd
/Another new issue: Linear Audio Volume 3! Last edited by janneman; 16th September 2009 at 04:15 PM. |
| Page generated in 0.08175 seconds (72.47% PHP - 27.53% MySQL) with 9 queries |
