many of our sources like CD players - tuners feature mute circuits in the analog audio outs .
I presume that the specific mute circuits are installed there to avoid digital and/or other noises to come out in the analog line out . i wonder if those circuits beyond the benefit of muting do they have any effect in the sound quality since are directly involved in the signal path opinions are welcome regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
ok ...here we go
i also noticed that in a technics tuner except the muting circuit there is also a lot of filtering in the out .... its a simple tuner that the sound comes out from a humble AN 7470 this we have to take as a fact ....not much you can do about that ... beyond that there is a astronomical 15nf capacitor that goes from signal to ground and a coil of some nh in series with the signal removed the muting circuit totaly then removed the 15nf capacitor and replaced that with silver mica 300pf now the radio doesnt mute any more while searching for a station ( not really importand since all your required stations are in memory ) and also while changing from memory one to memory two there some kind of not really loud pop noise . though high become by far more crisp and clear ....then sound stage become more real and as about the low end didnt seen much eventhough i beefed up the capacitors in the output of the AN from 3.3 mfd to 10 mfd plus 100nf styroflex bypass any comments ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr Last edited by sakis; 10th September 2009 at 06:25 PM. |
#3 |
one other thing ....i would be more pleased if in the out a small relay existed than transistors that interfere with the signal ....
this i can try first thing in the morning with a CD player ... i ll let you know
#4 | |
Are you sure that 15nF capacitors aren't part of the FM de-emphasis circuit? The series coil in this type of tuner is usually present to reduce the residual 19KHz stereo pilot tone component. This was particularly important in the days of tape recording as the pilot tone, unless adequately filtered, would beat with the recorder's tape head bias oscillator, creating some ugly whistles. If the above situation is the correct, your 330pF would likely result in the audio sounding too bright. I am often surprised by manufacturers using transistors as (shunt) mute switches. Surely their non-linearity destroys audio quality? Regards, Steve |
#5 |
Removing the muting transistors can help with sound,but you need to somehow ensure that the "clunks and pops" are still muted,or it can do ugly things-A small relay is commonly used instead. I've re-purposed the existing muting transistor(s) to trigger the relay(s),it's pretty simple.
#6 |
this is what i thought also relay would be by far better ... i mooving to this direction soon ....
as about the cap yes ....high sounds too bright but on the other hand 15nf in the signal out is too much .... will look to go higher may be up too 1000pf but not 15nf thanks guys ..... will play arround a Sony cd player and keep you posted ( clunks and pops ....i could live with a few of these if my sound is getting a lot better !!!! )
#7 |
Among the long list of improvements for the Marantz CD players is the removal of the muting transitors....
Andy |
#8 | |
If the de-emphasis is based on a 75us CR time-constant, changing to the European standard would mean changing the filter capacitor to 10nF. Just a thought. Regards, Steve |
#9 | |
jd
/Another new issue: Linear Audio Volume 3! |
#10 | |
WELL....dont really think so ....i think that having a resistor to ground as termination in a line outpout signal is a diferent story than a transistor providing ground fro muting .... the idea is not to have anything messing arround with your signal ---- then again if i go for relay mode i would go fro shorting to ground than interrupt the line out signal .... ----- yeap i presumed that mods like that will be present in the marantz cd mod list ....BUT THE ALL THREAD IS WAY TOO LONG TO READ ... thanks jan and others nice to see you arround ....will do some testing any day now and see what goes on kind regards sakis
| Connecting Virtual Ground Circuits with True Ground circuits?? | Minion | Solid State | 1 | 12th February 2007 01:28 AM |
| Research on tubes and circuits simple circuits | Cazcotty | Tubes / Valves | 6 | 16th June 2006 12:50 PM |
| 85 powersupply circuits 58 charge circuits | gev | Power Supplies | 0 | 31st July 2005 11:27 AM |
| Mute resistor value | Lico | Chip Amps | 3 | 4th February 2005 04:40 PM |
| please help - no mute but did mute mod - tda1541 | loomis | Digital Source | 1 | 14th November 2002 10:54 AM |
| Page generated in 0.12692 seconds (82.21% PHP - 17.79% MySQL) with 10 queries |
