Old 10th September 2009, 01:51 PM   #1
Default Voltage gain for RB-960BX
Dear everyone,
I am thinking of bi-amping with a mix of power amps, the NAD 214 and the Rotel 960BX. As i plan to be using passive line level XOs, i do not have too much control in terms of gain matching.
The NAD 214 manual states a voltage gain of 28.3 (29dB), but i cannot find the gain for the Rotel 960BX. Is there a way to figure it out?
The link to the manual is there. Too large to attach, sorry.
http://www.rotel.com/content/manuals/rb960bx_eng.pdf
Old 10th September 2009, 02:07 PM   #2
Hi rhapsodee,
The manual shows an input sensitivity of 1V. For 60W into 8 ohms requires an output of 21.9V(rms). So the gain is x21.9, or 26.8dB.
Hope that helps.
Steve
Old 10th September 2009, 04:10 PM   #3
Hi Steve,
Thanks for the reply! So that's what it means, 1V input for full rated power into 8 ohms.
That's good news, as i was planning to use the Rotel to drive the mid + tweeter, and the NAD for the woofer, which needs a bit more gain for the baffle step correction.
Thanks again!
Gavin
Old 10th September 2009, 06:16 PM   #4
Hi rhapsodee,
Yes, input sensitivity is normally quoted based on full power output and, if stated as a voltage, is normally V or mV (rms).
You should have an interesting setup when completed, though you would need to manually track the L-R balance adjustment across your two amplifiers, if required.
Steve
Old 21st September 2009, 04:53 PM   #5
Hi Steve,
Yes, interesting, hopefully in a good way!
What do you mean by tracking the L-R balance between the two amps?
I have a rough plan for my passive XO, some details here..
8" NHT woofers for midbass
Appreciate any further comments!
Gavin
Old 23rd September 2009, 08:58 AM   #6
I was wondering how you intend to control the volume and source selection in your setup.
Steve
Voltage Gain Confusion!! apehead Tubes / Valves 6 6th November 2007 01:47 AM
6v6. 6lg Gain Max Voltage mrhotmark Tubes / Valves 1 2nd December 2005 08:55 PM
Rotel RB-960BX Power Supply derguteton Chip Amps 1 25th November 2005 04:42 PM
Rotel RX-960BX Power supply derguteton Solid State 2 25th November 2005 01:01 PM
dB into voltage gain???? AudioGeek Tubes / Valves 6 17th April 2004 01:25 PM
Page generated in 0.07272 seconds (84.78% PHP - 15.22% MySQL) with 10 queries
