Hi.
I'm recapping my Soundcraftsmen MA-5002A amp and I'm thinking of increasing the PS capacitors. This is a class H with 63V on the rails up to 125W and switches to 92V up to 250W. For the 63V it has 2 11,000uF at 60V caps and for the complement to 92V it has 2x 22,000uF at 30V. Question is: how high can I go? I was thinking 40,000uF and 60,000. Is it going to affect the in-rush current and cause problems? Thanks. -- Elias |
#2 | |
It's always I good idea IMO to fit an inrush liniter (NTC thermister) on the primary; the idea is that their resistance is high when cold, so when you cold-start the amp there's a soft-starting action. This isn't foolproof though as they take a while to cool down before they provide protection again. For the modest increase you're talking about you might well be OK though - I think you'd need to tack the new caps on and measure it. I wonder whether increasing these caps will actually get you anything though; what makes you think they're undersized at the moment? Cheers,
I am not an atomic playboy. |
#3 |
I added larger capacitance to my amp and it started blowing mains fuses.
I had to increase the value of the mains fuse to the next current value upwards.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 | |
Nothing really. I tend to agree with you that probably I won't get much improvement (the amp already sounds great) and besides I use it to drive some large Altec 1003B horns, so it's probably just using a few miliwatts I was thinking about it because people say that more capacitance gives better results, etc. I guess I'll just replace the caps with the same value because of the age. Thanks for the help.
#5 |
Well, I like to figure out the performance bottlenecks in a design and remove them in turn. I'm also a believer that if it isn't broken don't fix it, especially if you care about breaking it
If it sounds great now, I would spend the time and effort on improving acoustics instead.Larger inrush isn't an issue so long as it's managed correctly (NTC, delay fuse, up-rated rectifier etc) but I don't see much point adding the compexity and stressing these components without measuring some difference with and without the uprated part first. Just my £0.02 Cheers,
| increasing coupling capacitor value in we 91 | tmhajw | Tubes / Valves | 13 | 13th May 2009 12:25 PM |
| Soundcraftsmen Pre-amp | enzedone | Solid State | 2 | 27th March 2007 01:07 AM |
| Soundcraftsmen MA-5002a | mhirvon | Solid State | 0 | 17th May 2005 09:52 AM |
| Soundcraftsmen 220 | mig-ru | Tubes / Valves | 2 | 16th July 2002 06:11 AM |
| Page generated in 0.08300 seconds (74.46% PHP - 25.54% MySQL) with 10 queries |
