Old 9th September 2009, 04:38 PM   #1
Default pre amp/OP amp
is it possible for me to use a 7W amp as a pre amp or op amp?
and if i so how would it be wired with a tone controle unit and where would volume vontrole go?? and what is the gain??
many thanks harry
Old 9th September 2009, 05:08 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
You could, but you'd have to get a line output converter, something car audio guys use when they're trying to adapt stock head units that don't have a line level output to amplifiers that only have line inputs.
It's a temporary fix, but I wouldn't want to permanently use the system like that at home.
Does your power amp even need a preamp before it, or can you just put a pot in line to control volume?
Jim J.
Old 9th September 2009, 07:54 PM   #3
what potentiometers should i use??
Old 10th September 2009, 03:37 PM   #4
i want to buy a pair of peerless tweeters and have been told that they are 6 ohm impendance can i run them alongside a bass driver that is 8 ohms in the came cabinet will this screw up my amp??
Old 10th September 2009, 06:41 PM   #5
Glowbug's Avatar
You'd need a crossover to split the frequencies to each driver.
What's the rest of your system look like, what are you trying to do?
Jim J.
Old 10th September 2009, 09:52 PM   #6
iv got a 70W per channel power amp in to a single basspad type speaker that i mounted a tweeter in and i am making a pair for my Design technology project. the cabinet that i made i put an old peerless tweeter of my dads in and it sounds amazing but i need a pair but the ones i have looked at say that they are 6ohms and i thought that you had to match the resistances of the two speakers in the cabined even after the crossover! coz my bass driver is 8 ohms! ?? help me plz!! ps what potentiometres do i use for volume control???????
Old 10th September 2009, 10:30 PM   #7
Glowbug's Avatar
50K-100K audio taper pots should do the trick.
I don't know if I can help you much on Xover design, although I will say if this is your first build, I'd probably recommend buying a copy of the Loudspeaker Design Cookbook and reading it thoroughly
Jim J.
Old 10th September 2009, 10:32 PM   #8
kool thanks but im still confused as to whether the impendances will be ok??
Page generated in 0.08545 seconds (75.05% PHP - 24.95% MySQL) with 9 queries
