Old 9th September 2009, 05:02 AM   #1
Sheldon is offline Sheldon  United States
Default Discrete buffer notion
Apologies to Joe Rasmussen and Allen Wright for this variation on the Super Linear Follower. But wondering if it might work with a BJT on top?
Sheldon
Old 9th September 2009, 06:35 AM   #2
Banned
would this work?
Old 9th September 2009, 08:07 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Actually, it is a variation of my Tower power stage.
No, such a way it will not work. You need to add some voltage on the base, instead of dropping it. Use one CCS fro + rail to base, and a resistor from base to output of the source follower.
Or, one Zener from output to base, and one resistor to B+
Old 9th September 2009, 02:46 PM   #4
Thanks.
Quickly drew this up before going to bed, and thought I could eliminate the resistors. Somehow it didn't seem right, which is why I posted the question. Realize now, as Wavebourn notes, that I was looking at the voltage drop backwards. Sometimes tripped up on errors too obvious to see.
I like Lumba's LED approach, as it eliminates a cap, plus it lights up. Is there any advantage to a BJT in the top position, as compared to an FET? I guess I'd use a higher beta device than the 5551.
Sheldon
Old 9th September 2009, 03:20 PM   #5
Wavebourn's Avatar
If you like LEDs you may want to use one more, to give a little bit more of voltage between drain and source.
Old 10th September 2009, 01:23 PM   #6
Banned
Sheldon,
It should be a BJT in the top position.
Old 10th September 2009, 03:22 PM   #7
Thanks.
Might be a good simple example to motivate me to learn LT Switcher CAD.
Sheldon
Looking for discrete buffer circuits capable of several watts or so... Lingwendil Solid State 4 17th April 2008 03:52 PM
Best place for discrete buffer Khron Chip Amps 8 11th March 2006 05:16 PM
my first solid project, discrete WJ/diamond buffer digi01 Solid State 22 22nd April 2005 07:48 AM
Discrete X-over Buffer from LC Audio-URL needed Samuel Jayaraj Solid State 4 9th November 2002 07:59 AM
Discrete buffer stage for xover JoeC Everything Else 1 2nd February 2002 03:43 PM
Page generated in 0.09132 seconds (75.61% PHP - 24.39% MySQL) with 11 queries
