#231 | |
Excuse me? Compare the (contrary to reality) claim made in post 208: Krill - The Next Generation With the facts of the matter provided by someone who actually posted evidence of having run a simulation with the driver biasing resistor, instead of just saying that they did: Krill - The Next Generation This thread has once again moved on to feigned moral outrage by one wishing to evade the basic technical facts of the matter – that is what is “despicable” in the whole charade. Last edited by GK; 12th December 2009 at 05:09 AM. |
#232 |
Hugh there is no need for this acrimony, just step back for a moment and think about it. An output stage is sitting at say an amp into 4 Ohms. It matters weather it was at 4 amps 10 usec before or not. Past history is important. Any description that walks through a circuit in a DC matter does not describe the behavior in a dynamic sense. I'm trying to make you think about the misunderstanding without being confrontational.
Pain is never permanent Last edited by scott wurcer; 12th December 2009 at 05:19 AM. |
#233 | |
Oh, an just for good measure here is the operation of the 4-transistor pair output stage with a 220 ohm biasing resistor. The switching is much less abrupt, but it is still well and truely enough to make the krill circuit switch. |
#234 | |
Banned
#235 |
#236 | |
diyAudio Moderator Emeritus
Hi, AKSA,
If this effect caused by the bias chain, then it shouldn't vary much with different output transistors. |
#237 |
#238 |
diyAudio Chief Moderator
AKSA post removed on language grounds. Please watch your arguments tone in general in this thread gentlemen.
#239 |
here the simulations i made, measuring the power pnp
output device collector current across a 0.001R resistor, comparison between krill and a classic EF.... the graph show that the effect is intrinsical of the absence of driver bias..1K resistors where used for bias... regards, wahab |
#240 |
So, please allow me a simple question
I suppose none of you will never build it, but others may What would you want to happen here, further on, about the Krill ? |
| Symasym - the next generation (supersym) | ostripper | Solid State | 253 | 18th August 2011 06:47 AM |
| boltar generation x old school | badcompany | Car Audio | 2 | 27th July 2008 01:13 AM |
| generation x old school | badcompany | Pass Labs | 0 | 25th July 2008 04:32 PM |
| philips cd 202 first generation | daveyboy1964 | Swap Meet | 1 | 30th December 2007 09:40 PM |
| pwm generation | sundeep2802 | Class D | 1 | 18th March 2005 06:39 PM |
| Page generated in 0.14994 seconds (74.52% PHP - 25.48% MySQL) with 11 queries |
