DIY Curve Tracer for PC - Page 44 - diyAudio
Old 7th November 2013, 12:00 AM   #431
1audio is offline 1audio  United States
Here is a like to the manual for the TEK IC test fixture for their curve tracer http://www.ko4bb.com/Manuals/Tektron...ons_Manual.pdf It will give you lots of details and you may be able to make a clone enough to try it with Locky's curve tracer. If you do I'm sure others will be interested.
Demian Martin
Product Design Services
Old 7th November 2013, 01:41 AM   #432
locky_z is offline locky_z  China
My tracer can't match OP characteristic. Because it is the highest resolution and only 1 ~ 2mV.
Old 7th November 2013, 02:33 AM   #433
rsavas is offline rsavas  Canada
http://www.ti.com/lit/an/snaa047a/snaa047a.pdf
A good read!!
and
http://www.google.ca/url?sa=t&rct=j&...,d.aWM&cad=rja
Old 8th November 2013, 01:09 PM   #434
jkuetemann's Avatar
Default Finally got to use mine
But not without an issue appearing. my N MOSFET curve looks fine but my P MOSFET curve has issues. Any suggestions? Possibly a faulty relay?
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 8th November 2013, 01:38 PM   #435
Yup. something hairy going on, looks to be noise, could be bad connections.
How do pnp bjt's measure?
Lawrence, I should apologize for this statement
Linearity/distortion. You do not trust what TI specifies, good luck proving them wrong. I do not think that you can afford the equipment necessary to make a claim like that.
After reading Bob Peace's article's, it would be interesting to test for opamp linearity, as he has done. Bob Pease was a magnificent contributor to electronics.
As in traditional TI fashion, they removed the authors name from their updated app note, a shame really.
Old 8th November 2013, 11:37 PM   #436
Sk8Ter is offline Sk8Ter  United States
its alright don't worry about it...I think its important to test all components in a piece of sensitive electronics including op amps etc..
Lawrence
Old 8th November 2013, 11:51 PM   #437
Try connect a 100ohm resistor between PMOS gate and socket B.
Old 20th January 2014, 02:49 PM   #438
Default expanding on this design
Hi locky_z,
Are you still working on your tester design or is it considered a finished product?
I started a new thread for something that is somewhat similar to your excellent design, although a little different:
Convenient USB based transistor tester
If you are open to expanding on your idea, perhaps you would participate in the design work on what I have proposed.
Old 30th March 2014, 06:26 PM   #439
Default Curvetracer failed
Hi all:
I tried emailing locky Z yesterday but no reply yet. I have a curvetracer 3 months old...and the PC s'ware config 'device not detected' no longer detects it although the PL2303 port is detected and the curvetracer relays click once the USB is connected. I am using Com4 as the virtual port as indicated by the device manager, Win XP SP3. No yellow flagged driver probs.
Reinstalled the supplied PL2303 driver (2013) with no probs.
Any thoughts on what to do?
thx
Ancel
Old 30th March 2014, 08:27 PM   #440
Default Intermittent
After removing the cover and measuring the key voltages, Vcc = 41, then 24, 12.16 and 5.1. Also tested the insulation of the transistors from the alum. sink which were ok. I tried it again and it started working.
So I don't know what it is yet, although the hand soldering job seems a bit poor.
Anyway I reassembled and it is still working for now.
Burnt out 2 small signal transistors by trying Hfe scripts w/o identifying if they were PNP or NPN. So the overcurrent LED works as well....
Auto tested a DUT to identify an NPN...works fine.. Did some HFe scripts on it...seems ok. Seems the Ic is measured in decimal mA....but volts are in V.
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 07:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 09:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 06:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 02:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 05:22 PM
Copyright 1999-2017 diyAudio
