DIY Curve Tracer for PC
Old 19th August 2013, 06:34 AM   #421
AmpliFire is offline AmpliFire  Netherlands
AmpliFire's Avatar
thanks locky !
Old 6th November 2013, 06:46 PM   #422
Sk8Ter is offline Sk8Ter  United States
Default Thinking of purchasing one of these
guys I have never used a curve tracer but am a quick study! I have BP ouputs i want to match and some smaller driver and signal transistors....this should do the job...
the question is did anyone adapt to measure/match op amps? this would be very helpful for what i need to do..
Lawrence
Old 6th November 2013, 07:42 PM   #423
1audio is offline 1audio  United States
What are you trying to match on opamps? While there are curve tracer methods for opamps you can do the same with a few simple test fixtures. A lot depends on what you want to know and what data sheet factor you want to check. Many datasheets, especially older ones include test circuits and that's a good starting point. You would need a good dual adjustable bench supply, a suitable signal source and whatever is appropriate for measuring the target parameter, a meter, oscilloscope or possibly distortion analyzer.
Demian Martin
Product Design Services
Old 6th November 2013, 07:51 PM   #424
Hello Thanks for your reply...I am mainly looking for gain matching and linearity matching...and or any inconsistency between them
Lawrence
Old 6th November 2013, 08:44 PM   #425
Probably the easiest and best would be the method on page 7 of this app note: http://www.ti.com/lit/ds/symlink/opa2604.pdf . What it does is reduce the available gain to drive the feedback network so the intrinsic distortion is reduced less by the feedback.
There are variations in the datasheets for other low distortion opamps. The distortion measured is directly proportional to the linearity.
Usually this turns out to be useful only for finding defective parts. Good IC's are really uniform making the whole effort tedious and somewhat pointless.
Demian Martin
Old 6th November 2013, 09:22 PM   #426
Default Thanks
Hi Thanks but I was hoping that i could use the curve tracer to test a bunch of these opamps...
to be honest I do not trust opamps and want to match gain and linearity/distortion....please remember this is for an audio device 2channel etc..
Lawrence
Old 6th November 2013, 09:37 PM   #427
rsavas is offline rsavas  Canada
Lawrence,
You set the gain of a opamp by determining the feedback ratio. Accuracy is a function of the resistor ratio accuracy Usually you use 1% R's for this. For very precise ckts you use even higher precision R's, but they are not generally needed for audio work because 1% gain accuracy is more than enough for most audio ckts.
BTW, what do you not trust?
Gain set by you R selection.
Linearity/distortion. You do not trust what TI specifies, good luck proving them wrong. I do not think that you can afford the equipment necessary to make a claim like that.
Rick
Old 6th November 2013, 10:16 PM   #428
Default yes sir
Yes personally dont care to prove anything to anyone its for my own enjoyment Thanks anyways
Lawrence
Old 6th November 2013, 10:21 PM   #429
Its true that if you need either really precise gain (.0001% or better) or very large gain more that 120 dB the open loop gain will be an issue. It terms of nonlinearity the opamps of a given type will be very similar. These are usually controlled by passive R's and C's on the chip.
The manufacturing process is designed and optimized to yield really consistent parts. Most IC processes are more controlled than discrete parts. Any significant variations would make a part with 1 billion transistors impossible to make and Intel makes lots of them.
Demian Martin
Old 6th November 2013, 10:38 PM   #430
yes Sir you defiantly know much more then I... but I shure would like to make shure what i am installing is a good match and working properly
thanks
Lawrence
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
