DIY Curve Tracer for PC
Old 19th June 2013, 03:12 PM   #411
palmito is offline palmito  United States
palmito's Avatar
Default smt jfet matching suggestions?
Has anyone tried using the tracer to match smt sized jfets? Just wondering what jigs/adapters could be devised to use in the curve tracer, if any. Any ideas would be very welcome! Thanks.
Old 19th June 2013, 04:20 PM   #412
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I use small gator clips to measure sot223. They have adapters, but they are kinda high.
...Shape the sound , Man!
Old 19th June 2013, 05:01 PM   #413
palmito's Avatar
Thanks buzzforb. I assume "kinda high" refers to the price? Can you post or pm me a photo of your setup, just want to verify clip size and wire length (or did you solder pins to the clips and stuck those in the curve tracer?).
Old 19th June 2013, 08:06 PM   #414
buzzforb's Avatar
Radio shack sells them. As you can see, by flipping the SOT 223, you can have everything flat on a pcb. I have gate and Source clips soldered to pcb trace with drain attached to piece of wire for easy clipping. The board is designed to insert into the tracer inputs with right angle pins. I'll see if I can fish it out of dungeon.
Old 19th June 2013, 08:31 PM   #415
palmito's Avatar
Thanks, hope you can find it!
Old 22nd June 2013, 11:43 AM   #416
NicMac is offline NicMac  Italy
NicMac's Avatar
Default LU1014D
Has anybody tried to trace these power JFETs on locky's device?
I get weird curves when I try to do the transfer functions (i.e. N-JFET Vgs/Id (Fix Vce))
Old 22nd June 2013, 11:59 AM   #417
buzzforb's Avatar
I tried once and also had trouble.
Old 22nd June 2013, 04:50 PM   #418
locky_z is offline locky_z  China
Can you post the measure condition graphics and the measure result save data file,
Old 18th August 2013, 10:51 PM   #419
AmpliFire is offline AmpliFire  Netherlands
AmpliFire's Avatar
Hi Locky,
Your tracer is no longer available on eBay? Are you out of stock? Will you have some new ones coming soon?
Old 19th August 2013, 12:53 AM   #420
Originally Posted by AmpliFire View Post
Hi Locky,
Because ebay only allow me sell 5 item once, When they sell out, I need to list them again, and the ebay link also change.
The lastest ebay link is: http://www.ebay.com/itm/locky-zs-Intelligent-curve-tracer-/111102327920?pt=LH_DefaultDomain_0&hash=item19de36 fc70[/URL]
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 07:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 09:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 06:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 02:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 05:22 PM
Copyright ©1999-2017 diyAudio
