DIY Curve Tracer for PC - Page 33 - diyAudio
Old 10th January 2013, 07:18 PM   #321
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by CeeVee View Post
Thanks Nic,
But...Rdegen trick comes at a price....slightly higher distortion, read this somewhere !, and according to Patrick ( EUVL ) deviating from 5R1 is to be avoided.
I fail to understand this but then that will be because i don't know enough of the subject.
My reasoning was in line with what you just laid out, the lower the Rdegen needed the better i thought. 5R1 being an average value.
I'd love to get the facts on this.
I think the idea of the trick is to lower distortion at the cost of higher local feedback (degeneration).
I am quite sure Patrick picked 5R1 because this is a value that "in average" will yield most NP-matches.
Maybe lower is better, but remember that there is already 11R is series in the F5X.
I think having different Rdeg for each J74 is a DIY'er luxury which can only be recommended
Anyway - wrong thread.
Old 10th January 2013, 09:27 PM   #322
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Yep...wrong thread but nice discussion ...see you on the proper one
Old 10th January 2013, 09:30 PM   #323
buzzforb's Avatar
P3 accomplishes similar, correct.
...Shape the sound , Man!
Old 11th January 2013, 01:53 AM   #324
locky_z is offline locky_z  China
System the principle of measuring voltage as shown below.Example measure the Vbe,
The BE two points of the voltage applied to the ADC input after 91K/12K resistor divider.
If R1/R2 and R3/R4 do not match. R1/R2=91K/12K R3/R4=91.09K/12K
When close sw1, Real Vbe is 0V. But because the resistor no match,The voltage difference between the AD1 and AD2 is
36* (12/(91+12) - 12/(91.09+12))=3.66mV
The system according to the measured, and then multiplied by the coefficient of the resistor divider, and it consider the Vbe voltage is:
3.66mV * (91+12)/12=31.4mV.
So if you measure the JFET Vgs-Id curve, system consider Vgs=0, But in fact the voltage of G/S is not zero.
This error voltage will change with the ground voltage (V) varies.
And when you measure N type ,the Ve is set to 2.5V,and measure the P type,the Ve will set to 36V. So At difference Ve,the error voltage is no same.
So I used some correction algorithm, possible error voltage Ve = 2.5 to 36V range to minimize.
The following diagram is shorted BE and shorted CE,and show Vbe / Vce voltage curve under different Ve.
File Type: png 20090604_52d3d53c250e4ab4d649KUHWZpYR9nz0.png (34.3 KB, 339 views)
Old 11th January 2013, 09:42 AM   #325
jeepy is offline jeepy  Switzerland
Originally Posted by locky_z View Post
The 2sa970 component foot is right?
Send the save data(.cuv) to me.
When start the measurement, the system control 3 channel output only moment of voltage.
When measure finish, 3 channel output to 0.
If you want to measure 3 channel output voltage by DMM, you can select menu 'option->diagnoosis' and 'Device Test' page -> 'Voltage Test' box,
Set the 3 channel output voltage and click the 'Output' button,
Then you can get the static voltage.
Old 11th January 2013, 09:45 AM   #326
I locky-z, thanks for the reply. This is the screen shot for the 2sa970: I alyways get very low hfe I do not not know to send the .cuv file.
Old 11th January 2013, 10:34 AM   #327
The NPN (2sc2240) test seems to be ok!
Old 11th January 2013, 11:41 AM   #328
2SA970 you need to load the 'PNP Ic-Hfe' condition.
PNP's voltage is negative.
Old 11th January 2013, 11:56 AM   #329
It is what I did. I tried 3 different types of PNP transistors with always the same problem: hfe = 2 to 3. Again, The NPN test is OK as you can see on the picture! Could something be wrong with the board? Unfortunately I cannot aford to spend days to fix. Any suggestion will help, thanks
Old 11th January 2013, 12:19 PM   #330
The PNP measure condition is:
But from your picture,I think your condition is NPN type.
Normaly in PNP's result data,The Vce is negative, Ve is +35~36V.
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
Copyright 1999-2017 diyAudio
