DIY Curve Tracer for PC
Old 12th January 2010, 01:28 PM   #21
barclaycon is offline barclaycon  United Kingdom
Default USB Curve Tracer
USB Curve Tracer.
I started a new thread about this.
Didn't want to impinge on the project that's in progress here.
Old 12th January 2010, 01:58 PM   #22
iko is offline iko  Canada
iko's Avatar
Where is it? Could you post a link to it please?
Edit: I found it, it's here http://www.diyaudio.com/forums/equip...ml#post2044632
Old 13th February 2010, 07:15 AM   #23
EUVL is offline EUVL  Europe
We tested one example from Locky_z. We also got the documentation including description of the circuitry, with a lot of clever thoughts. It is also one of the very few curve tracer available to DIY'ers which can provide test current up to 3A. Most others published on the net and/or available on the net (e.g. that from Elektor) can only test with say 20mA or so, i.e. no use for power devices.
As there is no uP on the board, the entire measurement procedure is controlled by the PC, which explains the need for parallel port. We did have some problems loading and running the software on English Windows, and used a PC with Chinese Windows in the end. But I think this is solvable.
Once set up, it is pretty easy to use, very versatile, and does pretty much everything we want. It is a bit of a shame that the creater has limited his choice of components due to cost considerations. And at that selling price, one can probably understand. The PCB layout is not brilliant, and some of the components are rather marginally dimensioned and suffer from thermal drifts. So if you do matching within minutes, it is probably good enough. If you want to compare measurements with months or years in between, there is quite a bit of refinements required.
We are, for our own purpose, working on improved hardware and PCB layout, and shall include active temperature control of the DUT (adjustable from room temperature to 100C). Quite a bit of work, so it will take a while. And above all, it is someone else's intellectual property. So whether it will be made available to the public eventually will not be our decision.
But it is a very handy piece of kit, cleverly done, and have great potential if we allow the use of much better components (e.g. reference resistors with low thermal coefficients). So congradulations to Locky_z for the great work.
Patrick
Old 30th March 2010, 04:26 AM   #24
locky_z is offline locky_z  China
the kit include circuit,you can layout the PCB.
there are some value in circuit may be diffent,and you can change it from software.
the English Version software is doing,
once finish ,i will send you to try.
but I can't not send to "wkypb@hotmail.com" beause the server filte it as "spam-like" .
Old 30th March 2010, 04:47 AM   #25
Thank you for your input.
You can send me a private email through this forum by clicking on my nickname.
Then I shall reply you from there.
Looking forward to your English version.
We'll give you our feedback. If you need further help, just let us know.
Patrick
Old 30th March 2010, 03:03 PM   #26
housing is offline housing  Hong Kong
locky_z,
Keep up your good work. My ancestor came from XH also.
Old 30th March 2010, 03:41 PM   #27
Danish is offline Danish  United States
I am looking forward to the English version of this DIY Curve Tracer.
Old 6th April 2010, 03:21 AM   #28
Re EVAL
>>>>In your circuit board and schematics, you are using a 10 pin connector to connect to the PC parallel port. Can you tell me the pin assignment that corresponds to the 25-pin D-sub connector of the PC (i.e. which pin from the 10 pin connector goes to which pin in D-Sub) ?
DIY Curve Tracer for PC-sub-gif
if you use another pin assignment,you must change the software option of "端口定义"
>>> Also in the current generator circuit for the base current, SW3 is connected to Vref in current mode according to the schematics. Should that not be Vref / 2 if you want to generate both positive and negative current without further switching ? If I understand correctly, J5B only switch between voltage out and current out, but not positive or negative current.
the current generator circuit As described
DIY Curve Tracer for PC-current-png
when J5 switch as above,B_PA is work in voltage out
if J5 is another size, B_PA & U6 is V/I circuit, I=(V5a-Vref)*K/R12
Here have some attention:
when U5a out is less Vref,then the B_PA out current direction is pull,mean is "Negative" current.But base on GND ,all current is positive.
Beasure the DAC(M62359) can output 0~11.5V, V5a is out 0~13V,Vref=6.5V is the best. but I lazy,I instead of it with Vref.
>>>>One more question for the DAC. If I want to use AD5308 instead (cannot get M62359, already obsolete), I should connect the SYNC pin of AD5308 to Pin4 of the 10-pin input connector, and LDAC pin to Gnd; is that correct ? Thanks and best regards,
The CT need more 14bit step DAC, but no need high precision or linearity DAC,so i use two 8 bit DAC out mix , as a 14bit DAC.
If change DAC,the source code must change ,becase M62359 control byte is no same with AD5308.
Old 8th May 2010, 08:13 AM   #29
Default Being translate to English Version
At the space time ,I also develop the USB version ,
I use C8051F330+PL2303HX link to the old "parallel port Version CT"
PC software through USB communicate with C8051F330, and control the old "parallel port Version CT" measure.
DIY Curve Tracer for PC-1004200918ed1ed4fb55f9689a-jpg
USB version the most measure speed is 86 point/sec.
If you want more precision,then slow down to 9 point/sec(66 times sample and average)
The image below is 66 times/18 times/ 6 times/ 1times sample to measure 2sc3281's hfe-ic curve.
DIY Curve Tracer for PC-10050815421be9a61bae8f69dd-png
Old 8th May 2010, 08:36 AM   #30
Dear Chung,
Thank you for the answers.
M62359 is no longer available (maybe still in China but not anywhere else).
We need to use a newer DAC, like the AD5308.
The USB version is interesting, but I think parallel port is also fine.
Any progress with English software ?
Can we help you ?
Mark will contact you by email.
Patrick
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
