DIY Curve Tracer for PC - Page 29 - diyAudio
Old 6th September 2012, 07:09 AM   #281
Every measurements of the board are OK and the first transistor checks as well
I will mount it with isolated holders in the case now.
Thank you all for the assistance.
Andreas
Old 18th September 2012, 04:25 PM   #282
Hi all,
One question about PNP/NPN HFE graphs...
I must be missing something, But the NPN curve works backwards for some reason..
What is the referance for the HFE ?? it is declining
Old 19th September 2012, 01:49 AM   #283
locky_z is offline locky_z  China
Originally Posted by BenY View Post
Hi all,
You need to checked once 'Calibration before measure' checkbox
Old 20th December 2012, 08:22 AM   #284
jeepy is offline jeepy  Switzerland
Board received!
Would this simple PSU with a lm317 + TIP 2955 be ok?
Thanks alot!
Old 20th December 2012, 12:02 PM   #285
Originally Posted by jeepy View Post
Board received!
Thanks alot!
Yes,you can use any regulator PSU.
Old 26th December 2012, 11:34 AM   #286
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Default Nmos and Pmos don't agree
Hi Locky_Z,
I have a problem reading the transfer curve in Pmos ( 2SJ201 ).
In similar conditions i get the complementary Nmos ( 2SK1530 ) perfect but cannot get the Pmos.
Any idea why ?
The images of both are included, with settings for ver 3.5 of software.
In the 2SK1530 plot you can see the 2SJ201 plot up to where it stops at 1.6V Vgs
Edit: the transistors are genuine !
Old 27th December 2012, 12:03 AM   #287
Can you send me the save data file(.cuv).
Old 27th December 2012, 09:19 AM   #288
CeeVee's Avatar
Hi Locky_z,
Here is the cuv file with a 2SJ201 and a 2SK1530, i tested a few dozen of each and they all show same disparity.
I used lots from diferent sources, Zhou-fang, Audiophonics and from other forum members including a mached NNNNPPPP set for my forthcoming F5X which i know is very well matched.
Really would like to get the most out of your great board.
Carlos
Old 27th December 2012, 12:15 PM   #289
Your power supply capacity is insufficient, or something wrong with E-channel amplifier source current.
From the P 2SJ201 Vgs->Id-1 data, you look at 'Ve' column, the 'Ve' is E channel amp output voltage.
At begining, 'Ve' is 28.3V, and when current Id increases, the 'Ve' decrease.
When Ve change more than 2V,The system considers Ve not stable, so it interrupted measurement.
Because measure P type,the E channel will setup to output high voltage and source current.
If power supply capacity is insufficient or the Q3(NPN) of E channel amp have wrong, the E channel output voltage can not keep stable.
please check the Q3(NPN) on the board.
Old 28th December 2012, 09:28 AM   #290
CeeVee's Avatar
Thanks Locky_z,
I tried my lab supply ( 30V 6A ) instead of the HP (30v 2500mA ) one and result is the same so it's not lack of PSU current capacity,
will check Q3, right now it has the Tip132 you fitted.
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
Copyright 1999-2017 diyAudio
