DIY Curve Tracer for PC
Old 3rd September 2012, 07:02 AM   #271
andreasw is offline andreasw  Germany
Default Device not found
Hello curve tracer user,
I connected the curve tracer in accordance to the manual.
The Power supply is the recommended HP 32V DC 2500 mA.
When I connected the USB cable the PC shows me "new hardware found and ready to use".
I started the software and followed the steps written in the manual.
But then the system shows me "device not found".
The com port is the right one.
I noticed that the heatsink is getting hot very quick and I made some measurement of the temperature (see picture attached).
In my opinion it's very hot.
Thank you in advance for your help.
Andreas
Old 3rd September 2012, 08:05 AM   #272
Bksabath is offline Bksabath  United Kingdom
Banned
Yes definetly sometink badly wrong
Mine get sligtly worm after testing 50 big dudas
Old 3rd September 2012, 08:08 AM   #273
BenY is offline BenY
Did you insulate the screws going through the power transistors??
I don`t see the plastic bushings there..
Old 3rd September 2012, 08:23 AM   #274
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Screws are making contact with front face of transistors and you have multiple shorts. Always test transistors for sink isolation with DMM resistance check. Simple, fast and safe
...Shape the sound , Man!
Old 3rd September 2012, 08:39 AM   #275
I used plastic bushings and insulating foil.
Maybe one foil is damaged.
I will check it with a DMM tonight.
Thank you.
Andreas
Old 4th September 2012, 03:17 AM   #276
locky_z is offline locky_z  China
the LM317 hot,may be 24V output wrong.
You can short socket 'X Y Z' and power on, if 24V 12V 5V and MCU is ok,you may hear some relay sound.
Old 4th September 2012, 08:48 AM   #277
I did the DMM resistance check and it seems like that 3 transistors ( the red circles) have contact to the Aluminum-angle.
I removed the angle and find out that they have contact to the Aluminum ground-plate as well
Then I removed the board from the ground-plate and everything works.
I did the DMM resistance check between the "red" transistors and the metal-ring fixture hole (yellow) and find out that they are connected.
I will fix the board with plastic bushings or plastic stands and then I hope it will work.
Does all the other user have plastic cases or fixed the board with insulation parts or is there something else I have to check?
Old 4th September 2012, 12:52 PM   #278
buzzforb's Avatar
Mine is totally isolated.
Old 4th September 2012, 08:59 PM   #279
Leatherface is offline Leatherface  Germany
Hi Andreas,
could there be something wrong with your fixing to the ground plate? As I understood from your description, the function came back when the board wasn't fixed on the ground plate any more...
BTW, it's O.K. that the three parts on the side have connection to ground (the first is the 12V voltage regulator with Pin 2 to GND and the other two ones (Q1, Q4) are the PNP transistors with Collector connected to GND).
Mine is buildt into a steel case (only isolated the parts on the side) and everything works fine!
Chris
Old 5th September 2012, 08:54 AM   #280
You also no use heatsink and power on 32V, but the LM317 may have a little hot,
And you can measure LM317 output is 24V,
measure 7812 output is 12V,
78L05 output is 5V,
If the voltage not ok, may have some compent error.
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
