DIY Curve Tracer for PC
Old 10th July 2012, 12:41 PM   #251
locky_z is offline locky_z  China
Their no polarity inverter circuit,
The PNP measure diagram is below
DIY Curve Tracer for PC-1-gif
If test PNP, System will set Eout to 36V,
And step down the Bout inorder to generate Ib.
System measure the Vrb,Vrc and calculate the Ic and Ib and Hfe.
The Vrb Vrc measure circuit is below
DIY Curve Tracer for PC-2-gif
It use a OP07 as follower, The op07 bias current and offset current will have some voltage drop on RB. But Op07 bias current and offset current less 5nA,and Op07 offset voltage is less 1mV,so OP07 only a little affect to DTU base current.
Old 11th July 2012, 09:30 AM   #252
Softwere update ,It can support script control.
The script is
V0=2.5
mode i
setrc 0
Eout V0
startwatch
color=random(999999)
for i=2 to 10
setib i
notice "IB=",i
for j=0 to 72
cout j/2+V0
waitrelay
getadc 2
ic=1000*vrc/currentRc
ib=1000*vrb/currentrb
curvepoint str(i),vce,ic,ib,ve
next
endcurve str(i),color
cout v0
next
d=stopwatch()
notice "time:",d
end
The software link
http://www.diyaudio.com/forums/attac...871_script.zip
Old 13th July 2012, 12:48 AM   #253
software update 2012.7.13
Bug fix:
1.if use negative parameter in setIb ,It have error.
2.add initialization currentRB,currentRC variables when press ‘run' button.
Old 13th July 2012, 01:03 AM   #254
carpin is offline carpin  Netherlands
carpin's Avatar
Thanks locky_z for the update
Old 13th July 2012, 07:47 AM   #255
Bksabath is offline Bksabath  United Kingdom
Banned
Hi locky_Z
Maybe this has been posted before
IS there a manual for the calibration of the curve tracer?
And maybe, more important, a way to return the curve tracer to original calibration if things go wrong?
Old 24th July 2012, 02:01 PM   #256
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Sorry to interject here.
I am wondering if a KIT for the USB Curve Tracer is avaialable for purchasing.
Thanks,
Stefano
Old 24th July 2012, 02:14 PM   #257
Lazybutt is offline Lazybutt  France
Stefano,
See the link to eBay in Locky_Z signature
locky_z's Intelligent curve tracer | eBay
Intelligent curve tracer main board | eBay
Fred
Old 24th July 2012, 02:36 PM   #258
Stefanoo's Avatar
thank you so much.
I will buy one...probably the finished product.
Stefano
Old 27th July 2012, 08:00 AM   #259
I wrote a component of the Tracer installation/ calibration/ diagnostic manual in chinese,
Who can help translate into English.
Old 27th July 2012, 12:20 PM   #260
Banned
I more than happy to help with tidy up of this but not good enough to start from scratch.
Your English is not to bad and if you get started we can get there...
DIY Curve Tracer for PCHide this!Advertise here!
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
