Old 14th June 2012, 03:30 PM   #231
NicMac is offline NicMac  Italy
NicMac's Avatar
Thanks Fred!
Is paint preinstalled on PC's with Windows?
Nic
Old 14th June 2012, 04:07 PM   #232
pchw is offline pchw  United States
Hi Nic,
Yes, paint comes with all versions of Windows (that I can remember). You can fire it up by typing "paint" in the run box or "Programs -> Accessories -> Paint".
One caution, typical Mac notebook keyboards don't have the <PRT SCR> keyword, at least not from my MacBook. If you are using Bootcamp to mutli-boot your Mac into windows, you will need to use an external KB, any 101 keys USB KB will do.
OT: spent a few days in Italy a couple weeks ago, lovely country.
- Fred -
Old 15th June 2012, 12:04 AM   #233
locky_z is offline locky_z  China
Originally Posted by NicMac View Post
attached as PDF. No zip tool on the Mac.
BTW: what is the easiest way to get the PC clipboard content into to posts on this forum?
I have observed these data 2SJ, Ve of the voltage is stable,
I think that the Vce=15V is too large.
When the current is greater than 3.5A,the voltage drop of RC may more than 3.5×4.55=16V,
System may hard to keep Vce=15V, and the curve is confusion.
You can set Vce=12V and try again.
Old 15th June 2012, 02:04 AM   #234
buzzforb's Avatar
Locky,
I have tried many different things with the P channel parts. Dropping the Vce has no effect on the outcome of my test. The only thing that allows it to test to 2500ma is to set the Vb steps high at .500mV. It is if the rapid step ups are robbing the bjt of current somehow. I have yet to be able to get the diode test to work either. I have tested the Diode using standard non linear IV curve without any trouble. Replacement parts should be here beginning of week.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 15th June 2012, 08:32 PM   #235
NicMac's Avatar
Ok. I exchanged both the LM568 op-amps with new branded LT1013 op-amps (LT1013CP from TI - beware that the LT1013 come in different packages!).
The curves now look better, but the tracer still "panic" at currents above 3.2A.
What to try next dear locky_z?
P.S. @Fred: thanks for the tip on how to attach images in Windows!
Old 15th June 2012, 08:50 PM   #236
buzzforb's Avatar
NicMac,
Did reducing Vce affect your mesurements any?
Old 15th June 2012, 08:54 PM   #237
NicMac's Avatar
The change of op-amps also seem to improve on the "interval narrowing effect", when measuring N-channel DUT's, but still not good enough.
I think locky_z would have a lot to gain (earn) by collaborating with us here at diyAudio so I'm sure he will come up with the fixes needed!
Nic
P.S. N-channel DUT in brown.
Old 15th June 2012, 08:59 PM   #238
NicMac's Avatar
Originally Posted by buzzforb View Post
NicMac,
No. Here @ 12V
Old 15th June 2012, 09:21 PM   #239
NicMac's Avatar
Better decoupling caps for the op-amp(s)?
Old 15th June 2012, 09:41 PM   #240
buzzforb's Avatar
Thanks NicMac. just for kicks, try upping your Vb steps to every .5V and see what happens.
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 29 21st May 2012 07:01 PM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
