DIY Curve Tracer for PC - Page 19 - diyAudio
Old 1st June 2012, 04:32 PM   #181
NicMac is offline NicMac  Italy
NicMac's Avatar
Locky_Z,
Can the device do transconductance curve tracing like the one showed in post #14 here?
Nic
Old 2nd June 2012, 03:10 AM   #182
locky_z is offline locky_z  China
This Vgs-Id curve,
You can load 'N-JFET Vgs-Id' measure condition.
And you can modify the 'Curve type' to control them show in different quadrant.
Example X Axis define is 'Vgs=abs(Vbe)' , abs() mean absolute value,so X-value is all positive,
Y axis define is ‘Id=abs(Ic)’, It is the same positive value.
So the curve will show in the first quadrant.
If you not use abs() function, The N-JFET Vgs-Id curve will show in the second quadrant,The P-JFET will show in the fourth quadrant, then you hard to compare them.
Old 5th June 2012, 02:12 PM   #183
NicMac's Avatar
Default troubles and suggestions
After modifying the device to do high current measurements I now obtain very reproducible traces to above 4A with NMOS DUT's. Moving to (complementary) PMOS devices, the curves however go "crazy" (fluctuate) at currents above about 2.5A using equivalent settings.
What is causing this? Anybody else seeing the same thing?
The device auto-numbering feature is useful, but would be much better if it gave an output like: "text-001, text-002, text-003 etc.", rather than: "text-1, text-2, text-3". It is painful to sort the current labeling in software like excel......
Old 5th June 2012, 03:35 PM   #184
You mean like this ?
Yes I do.
Curves are for an IRFP9240
Old 5th June 2012, 03:48 PM   #185
NicMac's Avatar
Yes, but much less dramatic. My traces continue to rice a still looks a tiny bit like curves.....
I will post an image when I find out how to make window screen shots on a PC and where the shots gets filed (unfortunately I'm a devoted Mac user)....
Edit: is it also P-Channel specific in your case or do you also see it on N-Channel devices?
Old 5th June 2012, 04:09 PM   #186
Also with NMOS, but much more reproductible. The last erratic point is always the same. I can see the overcurrent LED light up so I'm assuming this is linked to the current limiting circuit.
Below is the result for a SemiSouth power JFET (R100). All erratic points line up perfectly (there are several measurements there):
Below is an IRFP240:
Old 5th June 2012, 04:37 PM   #187
NicMac's Avatar
I see those you have shown in the post above when the current "roof" is reached and they are definitely caused by current limiting circuit. Possibly because another measurement is taken after the current has been turned of.
What I observe happens about 1.5A below the current limit.....
Old 5th June 2012, 08:52 PM   #188
NicMac's Avatar
Complementary N and P-Channel mosfets.......
Old 5th June 2012, 08:55 PM   #189
buzzforb's Avatar
looks like my etch a sketch graph
...Shape the sound , Man!
Old 5th June 2012, 11:58 PM   #190
I think the E-Channel power amplifier become not stable at large current.
The curve tracer‘s measurement is based on the ’VE‘ can not be changed.
VE output by the E-channel power amplifier guaranteed. Instability may have two kinds of situation,one is the output oscillation, one is the output voltage drop increases.
From the gray curve, You can see each point interval narrowing when current more than 2.4A.
This may be E-channel power amplifier output voltage drop increases.
You can view the measure data in the form of the curve, Observed 'Ve' column.
When the current increases, 'VE' value will increase.
Because Vgs=Vb-Ve, Vb increase->Id increase->Ve increase->Vgs reduce,so you see the interval narrowing.
'The power amplifier output voltage drop' control by the paramater 'options->Config‘->Voltage Drop(sink) & Voltage Drop(Source).
When measure N-type DUT, the E-Channel power amplifier is sink current,so the 'sink' parameter control this.
When measure P-type DUT,The E-Channel power amplifier is source current,so the 'source' parameter control this.
But the Green curve like 'sketch',I think it may be oscillation. you also observed 'Ve' column in the form data that the current more than 2.3A.
If the VE is a monotonically increasing or descending, then it is the ‘voltage drop’.
If the VE is random changes, then it is the oscillation.
If it is oscillation, may need replace the LM358 or TIP132/TIP137.
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
Copyright ©1999-2017 diyAudio
