#161 |
#162 | |
the PCB is
![]() The protect circuit ![]() In circuit the 'R*' is the ‘Green’ color resistor on PCB picture The Resistor of connect to 2SA970 base(18K) is Above 15V zener,SomeBoard may be 56K. You can first remove the R *, and then measure the power transistor , large current Vce-Ic curve, you can see the curve turning point was the maximum protection current, and then according to the schematic calculate R*. Quote:
Or You can use Excel to open the cuv file (File -> Open ->File type(All file)) The save file '.cuv' is txt type file and with ‘Tab-delimited’.
Intelligent Curve Tracer on ebay |
#163 |
I would like to find the Idss value. Is this where Vb=0 on the x-axis? |
#164 | |
However, due to the problem of measurement accuracy, there will be a few mV of error. When Vb=0,in fact Vb may be 5mV or -3mV, So I suggest, If you want to measure Idss,you can short Gate & Source,and then put them into E socket. drain insert into C socket, and load 'NPN Vce-Ic' or 'NMOS Vds-Id' condition to measure. Short gate and source of the JFET as a constant current diode,This ensures that Vgs = 0, Because B socket is NULL, So the condition of 'Vce-Ic' or 'Vds-Id' can be considered a two terminal device that connect C & E measurement conditions, After get the curve, It parallet to X-axis, the corresponding Y-axis is Idsss.
#165 |
I know this is a construction site and I dont want to take away the fun and time you are spending building from scratch -- However, anyone can buy a complete with CRT readout curve tracer from China --- Brand: SMT MAX, Model CA4810A curve tracer. Looks like a compact version of the Tek 576 but is new and does some things the old Tek doesnt. I bought one via the Internet and have used it... If this Pc version ever makes it to commercial market status, I'd buy one built.
#166 | |
On the plus side, it goes HIGH in voltageThe DIY curve tracer for PC does this digitally, (allowing printing, exporting, comparing, etc...), needs 5 minutes to setup, and weighs 2 kg I think we're comparing carrots and potatoes here. |
#167 |
How difficult would it be to convert the curve tracer to a scope/crt readout?
sam
Sam |
#168 |
#169 |
No PC.
From the curve tracer to an analog Oscilloscope. I have an Tek 2465 that I would like to interface to the CT. sam
Sam |
#170 |
No chance...
The CT output USB or serial data so you need a PC. |
| Using The Tektronix 575 Curve Tracer | Mark A. Gulbrandsen | Solid State | 29 | 21st May 2012 07:01 PM |
| B-H Curve Tracer | gpapag | Equipment & Tools | 9 | 16th January 2011 08:22 PM |
| curve tracer? | maxpou | Solid State | 4 | 24th October 2009 05:29 PM |
| Virtual Tek 576/577 curve tracer in EWB V10 | jackinnj | Equipment & Tools | 0 | 1st March 2007 01:41 PM |
| FS: tektronix 575 curve tracer | SQ Kid | Swap Meet | 3 | 11th July 2004 04:22 PM |
