Old 4th May 2012, 09:15 PM   #141
NicMac is offline NicMac  Italy
NicMac's Avatar
Default and completely dumb question.......
How do I plug in the jfet pins (gate, source, drain) into the base, emitter and collector slots
Old 5th May 2012, 01:54 AM   #142
Bksabath's Avatar
G = B
S = C
D = E
I think but is you use the component tester it can recognize the DUT and tell you a bit more
I am not near it at present but I can look later and report back
There are a couple of test for J fet in the menu
Old 5th May 2012, 09:57 AM   #143
Originally Posted by locky_z View Post
'The big relays (J1 and J2 ) get very warm' is normal.
The relay coil resistor is about 1K, so under 24V supply,It will consume 0.5W.
You can change LM317 output voltage, reduce 24V to 20V,because relay can also work in 20V.
24V power supply is only available to the relay power, and followed after 7812, a 12V power supply to the DAC.
Therefore, 24V reduced to 20V, will not impact on 7812.
Hi Locky_Z
Does it mean I can change all the relays to 12V ones and just modify LM317 output to 12V ?
Reason for doing this is I prefer new components than second hand and I happen to already have Omron 12V ones in stock
Thanks!
Fred
Old 5th May 2012, 03:11 PM   #144
locky_z is offline locky_z  China
to Lazybutt:
Yes,you can change LM317 output to 12V, and change relays to 12V,
And you also need to remove the 7812. because 7812 is powered by LM317.
to NicMac:
measure FET ,you can insert G to B / S to E / D to C
and press 'Load Condition' button to load ‘N-JFET Vgs-Id(Fix Vce)’ measurement conditions,
The measurement conditions mean
1. It set Vb from -5V to 0V step 0.1V mean Vgs from -5V to 0V step 0.1V
2. Set constant Vce=10V mean Vds is fixed at 10V.
3. RB=6K mean Gate protect resistor choice 6K ohm
4. RC=75 mean drain current sample resistor is 75 ohm.
5. Imax=30mA mean measurement end at current reaches 30mA.
Old 7th May 2012, 09:10 AM   #145
NicMac's Avatar
locky_z,
To hopefully improve further this already very nice device I will be upgrading some components.
Firstly, I will be changing the current setting resistors to precision resistors with low temperature coefficients. I think I will need to calibrate the instrument after changing these components. Can you please instruct us how to do the calibration?
I will also relocate Q1-Q4 and replace these with new components. Do you have any suggestions what components to get for Q1-Q4?
Thanks for the help!
Nic
Old 7th May 2012, 02:41 PM   #146
Originally Posted by NicMac View Post
locky_z,
The temperature coefficients of current resistor is not very import.
Nic
Q1~Q4 need Darlington,Hfe>1500 Vceo>50V Icmax>8A,Pdmax>65W
such as tip142 147
Old 8th May 2012, 07:50 AM   #147
NicMac's Avatar
locky_z,
Thank you for the answers, I have a few more:
I have noticed that checking the box "calibrate" before measurement does not increase much the measurement time.
Does it improve the quality of the measurement?
Is it best to always choose this option?
How many curve traces can a file hold reliably before making the software unstable?
If I replace RC 4.55R with a 4.7R value how do I calibrate the device afterwards?
Thanks,
Nic
Old 8th May 2012, 09:02 AM   #148
locky_z,
The "Offset test" button is used to measurement "the error in different common mode voltage”, if you see the absolute value of Y-Axis more than 0.005V, mean need to check the "calibrate before measurement " and then re-press the "Offset test" button,
the system will calibrate again and use the new calibrate "parameter" on follow-up measure, so you only check the "calibrate before measurement " once is enought.
if you exit program or check "calibrate before measurement " have more then 30min,you may need to check it again.
Nic
a file can hold more 500 curve,
Nic
yes ,you need do a "current calibrate“ again.
Old 8th May 2012, 11:04 AM   #149
NicMac's Avatar
Thank you very much!
How is this procedure performed? How do I enter the new value for RC in the software?
Nic
Old 8th May 2012, 11:14 AM   #150
E007 is offline E007  China
Send a message via MSN to E007
Hi, locky_z,
So glad to see your design here and share with overseas friends.
Amps...
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 29 21st May 2012 07:01 PM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
Copyright ©1999-2013 diyAudio
