DIY Curve Tracer for PC - Page 13 - diyAudio
Old 13th March 2012, 05:12 PM   #121
Banned
Tanks a Bunch
Realy apreciated (a much beter explanation that I could have ever made)
Old 21st March 2012, 12:55 AM   #122
ilardi is offline ilardi  United States
Just received my Curve Tracer. All looks well, but I have two questions:
1)My board is missing the capacitor in the lower left of the drawing above, that was prone to being leaky. I assume it was found not to be necessary at all. Is that true? Or should I add one back?
2) What are the X,Y and Z terminals for?
Terry
Terry
Old 21st March 2012, 12:58 PM   #123
I will let Locky_Z answer to your first question...
X, Y, and Z terminals are for detecting an unknown device type.
Just put a 3 legged device in X, Y, and Z and the software will tell you what type it is (BJT, JFET, etc...) and what pin X, Y, and Z correspond to.
This is the "DUT Auto Detect" function of the software
It also works for 2 legged devices such as diodes or zener...
Fred
Old 21st March 2012, 01:39 PM   #124
Fred
Thanks Fred. I guess if I had read the documentation more closely I would have known that. Still, it is a very cool feature. I knew it was there-but now I know how to use it!
Terry
Old 21st March 2012, 02:33 PM   #125
locky_z is offline locky_z  China
Terry
The capacitance in red circle is 24V Filter capacitor, they areI in parallel, so install a capacitance is enough.
Old 21st March 2012, 07:05 PM   #126
Thanks for the quick feedback.
Terry
Old 21st March 2012, 07:11 PM   #127
One more question. While I have a connector for the power supply input that will fit, could you provide the part number for the unit connector on the board. I would like to find the appropriate mating plug since the connector seems to be 'polarized' and I would like to prevent myself from plugging the power in backwards.
Thanks again.
Terry
Old 26th March 2012, 12:48 PM   #128
Wise precaution !
Old 31st March 2012, 11:16 AM   #129
styrkv is offline styrkv  Norway
Hi locky_z
I want to thank you for making this very useful tool, at an affordable price.
And thanks to Fred for organising the GB.
Agree with Bksabath. Best money ever spent.
I have used a 33V AC, 200VA transformer saved from a broken labsupply, and regulated it down to 31V DC with a simple zener + power darligton sceme.
There is one issue however:
In the dropdown menu for RC the choises are: 1K, 75, 1K, 12K.
If I choose the top 1K were the 4R7 choise would be I get a very low reading.
I have taken some Oscope shots from collector to ground with corresponding curves for different settings, on the same powertransistor. (2SC 3281)
VB 0.5 to 30V, 0.5V step. Constant VCE 30V. Imax 2500 mA.
1 and 2, RB 6K RC 75
3 and 4, RB 91K RC 1K
5 and 6, RB 500 RC 4.7 ?
I would be very happy if there is a way to fix this.
Please let me know if there are any other measurements you need to diagnose whats wrong.
Old 31st March 2012, 02:38 PM   #130
Your measure condition is 'VB 0.5 to 30V, 0.5V step. Constant VCE 30V. RB=6K Rc=75'
From the following diagram
Vb from 0.5 to 30V, RB=6K,mean Ib is from 0 to (30-0.65)/6K=4.89mA,
if Hfe is 70,then Ic is from 0 to 342mA,
then the voltage drop at RC=75(Vrc) is 0 to 25.67V
because Vce+Vrc+5V must <= supply voltage, but your supply only 31V,
When Ic increases,Vrc increases, the Vce can not constabt at 30V.
you see this picture
A start can be maintained in the 30V, but as the current increases, the increase of Vrc, Vce won't stay, you will see the Vc drop.
the same RB=91K RC=1K,you can calcuate the Ib and Vrc drop range,
RB=500 RC=4.55
trhis picture I don't know why
Using The Tektronix 575 Curve Tracer Mark A. Gulbrandsen Solid State 30 16th June 2015 06:35 AM
B-H Curve Tracer gpapag Equipment & Tools 9 16th January 2011 08:22 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Virtual Tek 576/577 curve tracer in EWB V10 jackinnj Equipment & Tools 0 1st March 2007 01:41 PM
FS: tektronix 575 curve tracer SQ Kid Swap Meet 3 11th July 2004 04:22 PM
Copyright 1999-2017 diyAudio
