Amps go burrrrrweeeehp when turning off
Old 5th September 2009, 09:04 PM   #1
underwurlde is offline underwurlde  United Kingdom
Default Amps go burrrrrweeeehp when turning off
My amp upon turning off takes about 10 seconds to turn off (LED dims). During the final 1 second of power down there is a audiable whining, decreasing volume (obviously), increasing frequency, kind of like 'burrrrweeehp'.
Any ideas as to what may be causing this?
Andy
Old 5th September 2009, 09:15 PM   #2
Geek is offline Geek
Geek's Avatar
Bad design.
Amps as their supply bleeds off can get unstable and oscillate, or dump DC through the speaker.
A speaker delay relay can be a simple fix as not only does it add a turn-on delay, but cuts them off as soon as the power is cut.
Cheers!
Old 9th September 2009, 08:21 AM   #3
OK I understand that. The relay idea is a cure but not a prevention.
Any other insights please?
Andy
Old 9th September 2009, 08:49 AM   #4
juma is offline juma  Germany
juma's Avatar
It's not very probable that you'll get a valid answer to your question if you don't provide more details on your amp and PSU.
Old 9th September 2009, 09:12 AM   #5
^ yes, good point.
Old 9th September 2009, 09:14 AM   #6
Power supply is bog standard Torroid > Single full rectifier > 2x 6,800uF caps to give +33V, GND, -33V
Simple. (no regultors etc).
Andy
Old 9th September 2009, 09:25 AM   #7
81bas is offline 81bas  Germany
Try to place a 0.1uf cap in parallel to R10
Basically, this cap is not intended to prevent burrrwwheeps, but who knows, which processes are starting in this schematic under low rail voltage
Old 9th September 2009, 09:31 AM   #8
juma's Avatar
Well, Geek was right (post#2) - this design is so bad that it's a small wander that it works at all.
And you got a funny case of two wrongs that make a right (and screwing everything else in the process): no Vbe multiplier bias temp. comp. but there are enormous output trans. Re (2R2) to make up for that.
If I were you I'd build any of good and proven amps from this site (symasym comes to my mind) but if you don't find it appealing, even a LM3886 would be a worthy upgrade (and you can use same heatsink and PSU).
Cheers !
Old 9th September 2009, 09:43 AM   #9
^ Now that is interesting.
I am trying to learn about amps.... so I have started with an Cambridge Audio A1 (from the 80's / 90's) and am 'playing' with it.
This is my (poor) tinkering of it!
"no Vbe multiplier bias temp. comp."
How would one implement this?
Old 9th September 2009, 10:02 AM   #10
juma's Avatar
You can start from here:
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm
Final schematic is at the bottom of that page - Vbe multiplier is TR13 which is thermally connected to output transistors.
Amps go burrrrrweeeehp when turning offHide this!Advertise here!
This is how my new amp is turning out.. nikwal Solid State 5 7th October 2007 01:34 PM
Pop from amp when turning off speed3 Tubes / Valves 2 25th September 2007 04:59 PM
Are there any way of turning DC to AC jacquesl Power Supplies 32 2nd March 2007 09:40 PM
Turning a car amp into a pc amp JDAudio Solid State 3 16th September 2004 05:10 PM
