Old 8th September 2009, 12:27 PM   #51
Rhythm Willie is offline Rhythm Willie  Australia
Interesting Debate.
I have had a Sony XA7ES for many years now. It has extensive power supplies,variable unbalanced and fixed balanced outputs and an excellent output stage.
I have now tried 7 different good quality preamps including 2 valve pres with this player feeding AKSA 100N+ and more recently completed Aussie Amps nxV300 monoblock power amps. I have also tried a passive approach.
In every case after extensive listening I have ended up preferring the SQ via direct connection of the CDP to the amps. I now only use a pre for phono when using the turntable (Project Perspective).
A switching box would be handy and I suspect that many prefer preamps because of the quality/drive ability of CDP outputs are not up the standards of the rest of their system. I eagerly await Aussie Amps new DAC to try with the Sony. I also gather Audio Note DAC kits are good (but quite expensive). The latest issue of Aus Silicon Chip magazine also has an interesting DAC Project.
Old 8th September 2009, 01:23 PM   #52
How do you adjust volume?
regards Andrew T.
Old 8th September 2009, 05:24 PM   #53
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I have born in Copacabana..and lived there for 40 years long
Copacabana is my place.... Rua Miguel Lemos 51 was my adress..... very nice place...the best in Brazil i think.
here you have a picture from satelite....the yellow dots are the places i have lived and the hospital i have born.... i was inside the Copacabana fortification for 2 years long together my grandfather that was a civil responsable by the 305 milimeters Krupp cannon maintenance and hidraulical repair.
I am glad you like Brasil, caro João
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 8th September 2009, 05:26 PM   #54
Default Thank you Rythm Willie..... direct coupling is really better
and controling the volume into the CD player or DVD player.
Nothing in between.
regards,
Carlos
Old 8th September 2009, 05:48 PM   #55
burbeck is offline burbeck  United Kingdom
hi joao
i'm sorry if i did not make things clear, the amp does not have a problem its designed that way, it has a balance and a volume control, it is just a power amp.
the rated input sensitivity is 230mVfor full output, this is great for old tape machines and tuners they will drive it directly no preamp, some sources need attenuation ie cd player.
the reason i mentioned this amp is that this is unusual \ interesting, and designed by the great man John L Hood. and like i said before i keep coming back to it, sounds nice.
regards
bob
Old 9th September 2009, 08:54 AM   #56
Has unbalanced variable out,via manual or remote control. looks like a high quality Alps pot.
Old 9th September 2009, 10:01 AM   #57
anyone that has compared the fixed output with separate attenuation to the inbuilt variable output almost without exception says the fixed + attenuator is better.
Maybe your CDP is one of the exceptions.
regards Andrew T.
Old 9th September 2009, 03:29 PM   #58
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by destroyer X View Post
Please, dear moderators, increase editing time to at least 30 minutes.
As of September the 8th, the edit time has been extended to 30 minutes as it was with the old software.
Cheers.
planet10 needs your help:
Let's help Ruth and Dave
Old 10th September 2009, 05:11 AM   #59
Default Thank you Cal
regards,
Carlos
Amplifier discussion needed! tf1216 Subwoofers 2 26th July 2006 01:21 PM
Copyright ©1999-2017 diyAudio
