dumb question about class AB
Old 4th September 2009, 03:51 AM   #1
Borat is offline Borat  United States
Banned
Default dumb question about class AB
what is the difference between a low power class A amp and a moderate power class AB amp with a very high bias dissipating the same quiescent power ?
Old 4th September 2009, 05:43 AM   #2
ostripper is offline ostripper  United States
ostripper's Avatar
Nothing , no difference. A class B can be a class A, just grossly overbias it.
This would be unrealistic for even a NJW21193/4 (SOA considerations), so IRFP240/9240's would be essential.
(attachment is a happily overbiased class B amp)
OS
Old 4th September 2009, 12:51 PM   #3
there is a design situation where the ClassA amplifier is exactly the same as the ClassAB amplifier.
Take a 25W into 8r0 ClassA amplifier as the reference.
The peak output voltage for a continuous sinewave output signal is 20Vpk.
The maximum output current when driving a resistive test load is 2.5A.
The bias of the ClassA output stage is just >1.25A, say ~1.3A.
Now look at a ClassAB amplifier with a 4pair output stage using 130W To247 devices and Re = 0r068
The optimum bias for ClassAB is Vre <26mV. Take Vre=22mV as the optimum determined by distortion/spectra analysis.
Ib~324mA/device.
The total bias current is 1.294A, it is biased identically to the reference amplifier.
Both amplifiers are 25W into 8r0 and both deliver 25W of ClassA into 8ohm.
Both will deliver substantially more ClassAB power into lower impedance loads.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th September 2009, 02:09 PM   #4
stoc005 is offline stoc005  United States
stoc005's Avatar
They will sound different. The sonic signature or summation of all the distortions and noise of each is different. Other than that, they are very similar.
Old 4th September 2009, 02:21 PM   #5
Andre Visser is offline Andre Visser  South Africa
OS
With very bad 2nd harmonic distortion.
Old 4th September 2009, 04:52 PM   #6
Ib~324mA/device.
why will they sound different?
Please explain your thoughts.
regards Andrew T.
Old 4th September 2009, 06:26 PM   #7
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It is difficult to offer a general answer, as much depends on
the devices and the conditions.
Old 4th September 2009, 07:03 PM   #8
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
what is the difference between a low power class A amp and a moderate power class AB amp with a very high bias dissipating the same quiescent power [snip].
My 2 eurocents worth: Assuming that the AB bias is the same as the class-A bias, this implies that the class AB has higher supply/higher max output.
They will both work in class A up to that bias point. After that, the class A will start to clip, while the AB goes into, well, AB. As long as they stay below the class A clip point, difference depends on topology and devices.
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 4th September 2009, 11:16 PM   #9
Banned
if the two amps are mostly the same except one clips transients and another doesn't - then why not build all class A amps as heavily overbiased class AB amps ?
have transition from A to AB occur lets say 10db below clipping. if used to actively drive a tweeter such an amp would spend 99% of the time in class A.
Old 5th September 2009, 02:10 AM   #10
eyoung is offline eyoung  United States
eyoung's Avatar
Hola Compadres,
Is not the point of class a bias to get the transistor to a more linear part of the curve and to avoid crossover distortion. Taking into consideration my simple mind and how things work once you get past the working area of class a most designs go to ab as a sort of soft clipping. Just a disclaimer I am not an engineer and I defer to those that I revere.
Regards, Elwood
"Lead me not into temptation...I can find it myself."
dumb question about class ABHide this!Advertise here!
Dumb question, but... johnm Tubes / Valves 3 13th June 2008 10:14 PM
Dumb question. G Tubes / Valves 2 16th January 2008 08:16 PM
maybe this is too dumb a question... dannyspencer Solid State 6 18th April 2004 04:57 PM
Thi is probably a dumb question.... Konnan101 Multi-Way 4 11th January 2004 01:40 PM
Dumb Zen V4 Question Panelhead Pass Labs 4 26th April 2003 04:15 PM
Copyright ©1999-2017 diyAudio
