Old 3rd September 2009, 06:41 PM   #1
Default Protection circuitry reference
Inspired by a computer power supply, doug self's book, I thought I would bring this together, its always been a little obtuse to me, so here's a new way of looking at it.
I hope this brings a fairly unmethodical subject and gives it a newer intellectual rigour of classification.
I am not an expert, and comments are welcome
Some if not all the methods overlap between what could be called protection and sound engineering design decision, eg thermal and bias decisions.
1/ overvoltage protection
what's at risk in power amps? fet outputs by diode clamping the inputs
and clipping the dc power rails, use clip detectors...comparators?
I wonder if you can use a compressor circuit to protect here?
This is not often attended to in commercial hifi amplifiers
2/ overcurrent protection, aka underimpedance
very commonly implemented,
what's at risk...
the amplifier by the speaker impedance dropping to low
solution, current limiting methods
sometimes also VAS stage is protected here from too much drive?
3/ overpower
...hmm combination of overvolt and current, nothing to say here
4/ short circuit protection,
one of the biggies, infinite current,
psu can be at risk by caps, rectifiers and transformers going short
short on output transistors puts speakers at risk
solutions, fuses and relay protection mostly
also, I will add, inrush protection here, toroids and power supply caps can sometimes be effective short circuits that can cause some problems.
5/ overtemperature
heatsinks
bias
and fan cooling are all decent design decisions here
mains transformers are also at risk,
thermisistors used to monitor heatsink temperature, perhaps IC's too
6/ undervolts
, here I will call it AC powering on and off, muting circuitry.
7/ overfrequency protection
design decision, related to 1/ oscillation/stability techniques
rf and input slew limiting are used, too.
8/ underfrequency,
here one could say DC protection as in shorted speaker leads or output transistors
and an input band limiting filter will protect what is following from preceeding DC, over excursion etc.
finally, miscellaneous circuits I am not sure where to put into my scheme are 3:
output clamping diodes
zobel network
and the series inductor output network, all for excessively reactive loads, perhpas over and under impedance protection?
DC output protection circuitry priscared Solid State 22 10th February 2007 09:39 AM
Two questions about amplifier's protection circuitry Leolabs Solid State 8 20th January 2007 01:49 PM
DC output protection external circuitry priscared Solid State 6 23rd June 2004 11:19 AM
Amplifier Protection Circuitry cm961 Everything Else 2 20th June 2001 03:56 PM
Page generated in 0.07605 seconds (73.00% PHP - 27.00% MySQL) with 10 queries
