diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Removing/Bypassing Headpone ouput a good idea? (http://www.diyaudio.com/forums/solid-state/150847-removing-bypassing-headpone-ouput-idea.html)
hearingisbelieving 3rd September 2009 03:04 PM
Hi, looking to do a simple mod/improvement on my Pioneer A400. Just wondering if removing then bypassing the headphone output will improve the sound of the amp. :confused:
you can find the schematics for the A400 here (not sure how else i can attach them sorry)
http://www.hifiengine.com/manuals/pioneer/a400.shtml
hearingisbelieving 9th September 2009 06:23 PM
is there someone who can help me please?
VictoriaGuy 9th September 2009 06:30 PM
Originally Posted by ifitsoundsgoodlistentoit (http://www.diyaudio.com/forums/solid-state/150847-removing-bypassing-headpone-ouput-idea-post1914887.html#post1914887)
I think you will need a good imagination to detect any difference in the sound at the speakers, by doing this mod.
However, there are folks on this forum who can (?) tell the sound difference between different brands of switches, RCA jacks, etc. so it might be best to consult them.
Cheers
John
hearingisbelieving 9th September 2009 06:55 PM
hi john, the reason i am interested in doing this is that i recently bypassed the input selector and was rewarded with a HUGE improvement in sound quality - mainly the level of detail improved significantly. anyone with a pair of ears who isnt deaf would have noticed the improvement.
my thought is that by bypassing the headphone output i will shorten the signal path and remove an obstacle from it as well thus improving the final output.
anyone else?
saurus 9th September 2009 08:32 PM
It seems to me that if you don't have a pair of headphones plugged in, then there would be no signal through that part of the circuit, and bypassing it should not make any difference to the sound. I could be wrong though ...
VictoriaGuy 10th September 2009 09:18 PM
Originally Posted by hearingisbelieving (http://www.diyaudio.com/forums/solid-state/150847-removing-bypassing-headpone-ouput-idea-post1919889.html#post1919889)
anyone else?
And this improvement was verified by a double-blind test comparing modified and non-modified receivers....?
Or you 'remembered' the sound from before the mod?
Whatever works for you- after all, this is just a recreational hobby, nothing serious.
John
hearingisbelieving 11th September 2009 06:42 PM
Wow John that was subtle! If you are doubting what i am saying about the improvement without having any experience or involvement in the process then you might be jumping the gun a bit.
To answer your question, yes i can remember what the amp sounded like before i did the mod. i have been listening to the same amp and the same music everyday for ages so i know what it sounds like.
actually, given the state of the component i removed and the quality of the silver wire i replaced it with, i find it ridiculous that anyone would believe there could not be an improvement in sound quality.
yes this may be a hobby but i love music and love listening to it so for me this is something i take seriously - though i dont take myself too seriously.
the clue is in the (user)name!
Javin5 11th September 2009 07:23 PM
I have not downloaded the schematic, but it should be obvious that we are talking about two different things here. I assume that, as in most amps, the headphone is connected via a resistor to the amp output. No headphone, no loading the circuit. As this is on the amps output, the impedance there is very low, and the resistor plus the headphone have a much higher impedance than the speakers, so really no loading. You may remove it if you don't use headphones, but it shouldn't make a difference.
But on the input, your impedance is high, so the wiring is a bit more critical. However, no way should you get a HUGE difference when you bypass the input selector, unless something was wrong to begin with, e.g. a ground loop. I'm assuming, that you did this with a line input (e.g. CD or Tuner). Or was it the Phono-input?
There is something else you can try, which often makes some real difference: Bypass the speaker selector switches at the output (if there are any in your amp and you don't need them). Here you have high currents flowing. Connect the speaker terminals directly to the transitor outputs by using a short piece of speaker cable. If you do this and remove all unnecessary wiring, you also are disconnecting the headphone output at the same time.
Kurt
hearingisbelieving 12th September 2009 08:56 AM
Sorry about the confusion guys - i really should have posted this photo earlier to show you what I was dealing with in terms of the input selector:
http://img225.imageshack.us/img225/3601/picture149.jpg
Now hopefully you can see the extent of the corrosion/oxidisation evident directly in the signal path.
Javin5, thanks for your input, unfortunately I dont have speaker switching but atleast I wont waste my time with the headphone output now.
Resources saved on this page: MySQL 18.75%
